| tornik550 |
Feb 7 2010, 02:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am in the market for a new carb linkage. I currently have a hex bar linkage that has seen better days and needs to be replaced. I have dual weber 40 idf's. I have been looking around and haven't found many options. I do not have a lot of money to spend (another kid on the way and three Porsches in the garage).
What are my options for dual carb linkage. I can only spend up to about $150 however my wife would give me less problems if I spent more like $100. Where can I purchase linkages? I have only been able to find them at CB performance? |
| tornik550 |
Feb 7 2010, 06:41 PM
I am very interested in one of the CSP types. Does anybody have any pictures installed on a 914? I am curious about the throttle cable.
How does the one in the picture from above mount? Does it mount like the csp type pictured? Hard to tell from the picture. I am very grateful for everyones responses. Attached image(s)
| 7275914911 |
Feb 7 2010, 10:18 PM
Hummmm!!! ![]() ![]() ![]() Group: Members Posts: 757 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States
I am very interested in one of the CSP types. Does anybody have any pictures installed on a 914? I am curious about the throttle cable. How does the one in the picture from above mount? Does it mount like the csp type pictured? Hard to tell from the picture. I am very grateful for everyones responses. The CSP mounts at back of engine case. The first one would mount in middle of engine case. The CSP needs throttle levers on the same side of carbs. At the rear. I am using base from first one and bellcrank/rods from CSP. I will try snd find a pic of mine. There was a good pic of the CSP mounted at rear in a thread here somewhere too. |
tornik550 Dual Weber Carb Linkage Options? Feb 7 2010, 02:01 PM
sean_v8_914 Jake Raby sells a center pull linkage but your bu... Feb 7 2010, 02:07 PM
tornik550
Jake Raby sells a center pull linkage but your b... Feb 7 2010, 02:10 PM
7275914911 try CPI....they have a CSP bellcrank that is under... Feb 7 2010, 02:11 PM
sean_v8_914 http://www.cbperformance.com/catalog.asp?ProductID... Feb 7 2010, 02:27 PM
sean_v8_914 http://www.mamotorworks.com/acvw?frame=1.6564 Feb 7 2010, 02:34 PM
tornik550
W... Feb 7 2010, 03:11 PM
7275914911
[quote name='sean_v8_914' post='1270818' date='Fe... Feb 7 2010, 03:47 PM
jmill Check this thread out: http://www.914world.com/bb... Feb 7 2010, 03:56 PM
craig downs Thats a good linkage or you could wait a few month... Feb 7 2010, 10:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 03:20 AM |
