> Tires, What to buy
qa1142
post Feb 7 2010, 11:34 AM
Whiplash
So I have been running Falken Azenis for last 5 years...205/50 -15's and they have been very good for me.
My only issue is speedo and odometer is off ~10% (top speed too). This helps in autoX and it drops my gearing and tightens the ratio. (9.1% per tire calculator bu
What do you all recommend for tires these days, between track events and autoX it is time, even if mileage is only ~ 10k. What is "best tire" these days? Hear Yokohama's are really good too, Love the grip of these Azenis, and rarely see rain, this is sunny day car.
Second do I go with 195/65 -15 since I don't autoX and track that much any more? Or Second, can I re-gear 5th to put it back where it should have been on top-end and re-cal the speedo? Just expensive way to do it.....
What other options do I have?
Will 205/65-15 fit? What is best 195/65-15 option?
Thanks
Whiplash
r_towle
post Feb 10 2010, 09:56 AM
Custom Member
195/60/15 give you a great ride and its close to the right speedo setting.
205 width is nice, but you will rub (every car is different..YMMV) most likely in the rear or on the inner front fender.
205/50/15 in most tires (all have different profiles) will fit with not rubbing, but as I said..some do rub.
If you are no longer autoxing on a regular basis, go with the 195/60/15. It fits the wheel well much better and fills it in nicely.
You get a taller sidewall for a better and less harsh ride.
Khumos are a great tire for the money...that is this years set for me.
In Illinois I would suggest you stear clear of "extreme summer performance tires" due to the fact that they suck for traction at any temps below 50 degree...and cold rain is a roller coaster ride.
Rich
zonedoubt
post Feb 10 2010, 10:10 AM
Canadian Member
QUOTE(r_towle @ Feb 10 2010, 07:56 AM) *
Isn't 195/65/15 even closer to stock size? Or is it an availability issue for that size?
- Lo-Fi Version Time is now: 10th June 2026 - 02:06 AM
