Installed a front sway bar in my '75 today, Adjustable drop links... preload? |
johnnie5 |
Feb 11 2010, 10:02 PM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
Finally installed the sway bar today that has been sitting in my garage for a year or more. I set the adjustable heims the same distance as each other and bolted them into the u tabs.
Can someone please explain preload to me? Does it have to do with one drop link being longer than the other? |
McMark |
Feb 12 2010, 11:12 AM
Preload is....
If you remove the drop links all together, then lower the car, then measure between the a-arm and the sway bar ends you'll often find that each side measure differently. In order to remove all tension from the sway bar when unloaded, you may need different length (or better, adjustable) drop links to account for this difference. The bottom line is that you want the sway bar to be neutral until acted upon by outside forces. A preloaded bar is not neutral. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:01 AM |
