| tomkirkcis |
Jan 23 2010, 10:38 AM
Newbie ![]() Group: Members Posts: 49 Joined: 19-October 06 From: massachusetts Member No.: 7,064 |
.I have been running searches for a couple of hours but can't find any info on fitment of 7r fuchs on a 914.
I have a narrow body 1970 factory 914-6 that has a hot 3.2SS motor and a close ratio LSD box Dr Evil built for me. It currently has 205/50 on 6 x 15 fuchs. Not enough tire . I have some AA metal flairs I got in a group buy a couple of years ago that I inteneded to install. I have four 9 x 16 fuchs that I was going to install all around . Certainly would take care things I am having second thoughts about installing flairs. It is just so much fun having a stock looking 914 with a big motor. I have access to a set of 4 7r Fuchs with 225/50 Brigestones. These are the Fuchs with the large backspacing Is anyone have 7Rs fitted to a narrow body? What tires can you fit? What spacers? Thanks Tom |
| tomkirkcis |
Feb 13 2010, 04:02 PM
I have been traveling on business a ton, and was able to play in the garage for the first time. I took a set of 7R rims that are mounted with Bridgestone Potenza S-03 225/50ZR 15's. The 7R backset is listed as 138MM. I used a straight edge laid across the back of the tires and measured the backset at 6 1/2 inches to the rim mounting surface. I installed them on the rear of my 914. After rolling the car back and forth and bouncing it to settle, the inside fit is VERY tight, but clears. I would suspect cornering or bounce might cause contact on the inside. The ouside is also tight but might clear. The tight spot being the outside rear. My passenger sideis slightly tighter than the driver side.
I decided to use a high tech method. I went to the local Tractor Supply store and bought a pound of 1/2" flat washers I then used the 1/2" flat washers to space out the rims. Washers stacked 3 deep (about 8.5MM) "appears to give Just enough clearance on the inside. I have no idea why this looked to be enough space to me but it did. This would effectively reduce the 7R backset of 138 mm to about 130mm. All other fuch 7 inch rims, including both the 15" or 16" have a backset of 112mm . If my eyeball engineering is correct, the R's may have about an 18mm backeset advantage over other factory 7's. HaraldD's post above says he uses a 27mm spacer. This would reduce his 7R's backset from 138MM to only 111MM. Eric Shea's comment would be correct, This would be a very expensive way to get the same backset available from far less expensive standard factory 7" rims. The 225/50's on 7R look SO much better than the 205/50's on deep 6's. Not only the width but also the more correct height. I am thinking 225/50r rubber on 7's might be enough rubber. The only way to tell if they fit is to drive them. With the washers in place,It might just take the slightest of rolling the opening With the washers in place, I get 4 revolutions of the lug nuts. I am a little nervous thinking of driving with only 4 turns. Anyone know if I am asking for diaster? I am thinking limited testing, not a permenant condition here. I will have some images to post a little later. Tom |
tomkirkcis Narrow body fuch 7R fitment Jan 23 2010, 10:38 AM
dr914@autoatlanta.com The seven rsr wheel fits great with a 205 but not ... Jan 23 2010, 10:44 AM
tomkirkcis [quote name='dr914@autoatlanta.com' date=... Jan 23 2010, 12:22 PM
[quote name='dr914@autoatlanta.com' date=... Jan 23 2010, 01:26 PM
burton73
The seven rsr wheel fits great with a 205 but not... Jan 23 2010, 12:55 PM
underthetire I have the large backspace 16X7 dials on my narrow... Jan 23 2010, 10:51 AM
campbellcj There are other options for flares besides the fac... Jan 23 2010, 11:29 AM
tomkirkcis I have a pair of 951 8 x 16 that I bought as a pos... Jan 23 2010, 01:22 PM
burton73 Tom,
This is a picture of sixnotfour car wit 245-... Jan 23 2010, 02:56 PM
Tom,
This is a picture of sixnotfour car wit 245... Jan 23 2010, 03:20 PM
brant you actually might get the 225's depending on ... Jan 23 2010, 05:53 PM
tomkirkcis Thanks for posting the image. I am amazed 245 fit... Jan 23 2010, 06:08 PM
burton73 8x16 Offset 23.3 (944) Backspace mm 120
95... Jan 23 2010, 09:50 PM
Michael N This chart help me when I was trying to decide whe... Jan 23 2010, 10:32 PM
HaraldD Hello!
I`m driving 7"R Wheels all aro... Jan 24 2010, 02:59 AM
qa1142
This chart help me when I was trying to decide wh... Aug 14 2010, 12:16 PM
pete-stevers 3.2ss that is exactly what i am dreaming of buildi... Jan 24 2010, 11:03 AM
tomkirkcis Harald
Your 914 is gorgeous. Thanks for posting t... Jan 24 2010, 08:45 PM
tomkirkcis Pete
The engine has weber 46s with 40mm venturis,... Jan 24 2010, 09:01 PM
pete-stevers yup...sounds like a nasty lil machine, you will ne... Jan 25 2010, 12:47 AM
messix don't roll, use a thin cut off wheel on a die ... Jan 25 2010, 01:22 AM
mskala Tom,
There is no one answer for widest rubber in t... Jan 25 2010, 12:06 PM
sixaddict On a conversion, I have currently mounted 16 X 7 w... Jan 25 2010, 03:34 PM
burton73
On a conversion, I have currently mounted 16 X 7 ... Jan 25 2010, 09:38 PM
Eric_Shea Tom,
I don't see the advantage of 7R's on... Jan 25 2010, 05:41 PM
Michael N Check out the article in Oct 2006 Excellence. It ... Jan 25 2010, 06:42 PM
campbellcj I just checked my car yesterday at the track and t... Jan 25 2010, 07:53 PM
Eric_Shea
That would be the ticket. Have Harvey build a s... Jan 25 2010, 09:41 PM
underthetire I had 205's on my old rivi's. 5" rim ... Jan 25 2010, 09:42 PM
javadog I have a '71 six with 7R wheels on the back. ... Jan 26 2010, 08:19 AM
burton73 I tried on the tires for size with the old trailin... Jan 26 2010, 04:59 PM
burton73 I pulled down the tires that where on my car when ... Jan 26 2010, 05:05 PM
pete-stevers
That would be the ticket. Have Harvey build a ... Jan 26 2010, 07:09 PM
mskala The safer and more complete way is to disconnect t... Feb 13 2010, 05:36 PM
tomkirkcis
The safer and more complete way is to disconnect ... Feb 15 2010, 06:26 PM
davesprinkle
The safer and more complete way is to disconnect... Feb 15 2010, 10:03 PM
tomkirkcis Here are a couple of images.
Image of the 225/50 o... Feb 13 2010, 09:14 PM
Eric_Shea So, do they fit or do they rub?
I would "at ... Feb 15 2010, 12:02 PM
tomkirkcis I do not know. Racer Chris at Tangerine Racing di... Feb 16 2010, 06:23 PM
tomkirkcis Well, we did some test fitting on the front. I nee... Mar 7 2010, 04:03 PM
tomkirkcis Wheel stud length? I am confused as to what is th... Mar 13 2010, 06:22 PM
tomkirkcis I have had a chance to drive the car a couple hund... Aug 12 2010, 07:01 PM
qa1142 First, I want to say this thread rocks :headbange... Aug 13 2010, 04:44 AM
tomkirkcis
First, I want to say this thread rocks :headbang... Aug 13 2010, 04:43 PM
Bleyseng I had fittment issues in the back with 15x7 cookie... Aug 13 2010, 09:52 AM
qa1142 so these won't fit with 23 offset with?
Size ... Aug 13 2010, 11:45 AM
sixnotfour Here you go , bolt on , be happ, and light in the ... Aug 13 2010, 11:51 AM
Bleyseng and real deep dish rims to boot!! Aug 13 2010, 12:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 11:57 AM |
