911 Valve Adjusters for my Type-4 2.0L?, Good Idea or Bad Idea? |
ericread |
Jul 30 2009, 03:49 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Somewhere earlier I saw a comment that Jake had recommended using 911 Valve Adjusters in the Type-4 engine... Or maybe he had recommended against it. I can't remember.
Anybody out there have experience in this? My adjusters and adjuster nuts were pretty gnarled when I got my car a few years ago. Now with bi-monthly adjustments, I'm looking to replace them. Will the 911 adjusters fit the existing rocker arms? Do I need the same nuts? If I go ahead with this, should my properly adjusted valves run quieter? And is there any advantage to replacing the springs? As a result of some moderate leaky valve guides, my plans are to have the heads re-built this winter. Should I wait until the heads are rebuilt, or is there any reason I shouldn't go ahead with the adjusters, nuts and springs right now? Any thoughts? My thanks. Eric Read |
cdadaa |
Feb 14 2010, 01:35 PM
Newbie Group: Members Posts: 6 Joined: 25-May 09 From: Spring Creek, Nevada Member No.: 10,402 Region Association: None |
What is the desired "finish" measurement of the shaved rocker? Every stock 1.7 rocker I've measured has a different original reading, so taking 0.060 is relative to the starting measurement. Shouldn't all of them be the same finish measurement? Or does it matter?
Thanks...Dan |
Lo-Fi Version | Time is now: 1st June 2024 - 02:17 PM |
