911 Valve Adjusters for my Type-4 2.0L?, Good Idea or Bad Idea? |
ericread |
Jul 30 2009, 03:49 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Somewhere earlier I saw a comment that Jake had recommended using 911 Valve Adjusters in the Type-4 engine... Or maybe he had recommended against it. I can't remember.
Anybody out there have experience in this? My adjusters and adjuster nuts were pretty gnarled when I got my car a few years ago. Now with bi-monthly adjustments, I'm looking to replace them. Will the 911 adjusters fit the existing rocker arms? Do I need the same nuts? If I go ahead with this, should my properly adjusted valves run quieter? And is there any advantage to replacing the springs? As a result of some moderate leaky valve guides, my plans are to have the heads re-built this winter. Should I wait until the heads are rebuilt, or is there any reason I shouldn't go ahead with the adjusters, nuts and springs right now? Any thoughts? My thanks. Eric Read |
bandjoey |
Feb 14 2010, 01:51 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Way to go. Add these drawings to the save the technical stuff thread!
Is the only difference in the 1.7 and 1.8 rocker the size of the threaded post? 8mm vs 10mm? Is it worth the difference on a daily driver to change out the rocker arm just to get the 911 screws? Also does shimming mean add shim washers under the rocker arm assembly, to move it further away from the motor? |
Lo-Fi Version | Time is now: 1st June 2024 - 04:30 PM |
