turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
I did something similar wheb installing my cage. Went to a chassis shop up the street and had the fella bend the sucker. I had a tube to weld across the door gap (but down low) to hold it. It worked. I donno if it would have sprung back without the tube. Over bend (pre load) & pray is the way do do it before you do the work. Doing it after is iffy but has possibilities.
Lo-Fi Version | Time is now: 10th June 2024 - 07:39 AM |
