turnaround89
Feb 17 2010, 08:04 PM
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
nykthebartender
Feb 17 2010, 08:24 PM
How much is way off? You can shim the door hinges where they bolt to the pillar. A shim in the top moves the rear of the door downward, a shim in the bottom moves it upward. Tough to say without seeing it though.
scotty b
Feb 17 2010, 08:26 PM
If the latch is out, how does the door line up with the body ? Tight at the top or bottome? Rocked in or out at the top or bottom ? Sitting high or low of the body ? There is a fair amount of play in both the hinges and the latches. Get the door and body lined up then worry about the latches.
Best yet, post some pics.
rick 918-S
Feb 17 2010, 08:29 PM
yeahmag
Feb 17 2010, 08:32 PM
Yeah... Take the striker out and close the door. Show us the gaps.
J P Stein
Feb 17 2010, 08:33 PM
I did something similar wheb installing my cage. Went to a chassis shop up the street and had the fella bend the sucker. I had a tube to weld across the door gap (but down low) to hold it. It worked. I donno if it would have sprung back without the tube. Over bend (pre load) & pray is the way do do it before you do the work. Doing it after is iffy but has possibilities.
Feb 17 2010, 08:52 PM
QUOTE(turnaround89 @ Feb 17 2010, 06:04 PM)
If the door is off in the up/down direction, simply open the door and grab the back and slowly pull it up until it lines up ...
That's how the body shop would fix it.
Andy
bobhasissues
Feb 17 2010, 08:54 PM
What were you welding?
Engman kit
Clamshells
Other
As said previously, you have to post some pictures
McMark
Feb 17 2010, 09:31 PM
we need a bunch more info/pics.
turnaround89
Feb 17 2010, 10:23 PM
I welded in clamshells over the longs and also put in new inner longs as well. The passenger door sits about 3/4" low at the back. The strikers are then that far off as well. I have tried pulling up on the bottom of the door, however, if i pull up too much the triangular window will just make contact with the windshield frame. ill try to get some pictures tomorrow. The door sits really low.
Shims in the bottom may help a little, but once again, too many and the window will make contact with the windshield frame. Im really excited that the chassis is super rigid, but i don't like not being able to shut my doors.
davesprinkle
Feb 17 2010, 11:00 PM
That sucks. The only real option is to cut a few slots through the new sheet metal to allow the car to spring back to its natural position. Then weld up the slots again. This time slowly. Do a couple inches, then use an air compressor to blow it cool.
turnaround89
Feb 17 2010, 11:25 PM
the weirdest part is that the door hangs low at the back...i don't think the car is unsafe to drive, its just the doors will not line up. The chassis is way stronger than it used to be. I took some measurements, and the car has shrunk...the gap from the windshield frame to the targa bar is the only severely off measurement, everything else seems right
davesprinkle
Feb 17 2010, 11:41 PM
QUOTE(turnaround89 @ Feb 17 2010, 09:25 PM)
That's right, you've curled up the longs into a curve. The door sits low, the door opening is the wrong shape, the targa bar is too close to the windshield header, your wheel alignment is screwed.
It might be stronger, but it's definitely not better. I know this sucks to hear, but you need to try to undo this. You should cut a series of slots through the added sheet metal to relieve the stresses that you've locked into the car.
rick 918-S
Feb 18 2010, 08:21 AM
Don't bend the door! Fix the chassis. If you bend the hinges in the door frame you will build in a new problem. Someplace there are chassis dimensions. maybe here or on the bird site.
Or you can ge measurements off a known good car. Do you have a parts car with a good door opening? Even a rusted one usually had a driver side that is good (not sagging) You need to find out if the cowl is leaning back or if the latch pillar is leaning forward.
Don't assume anything check, check, check. Then cut through the chassis stiffening and use a port-o-power to adjust the gap back. You will have to push past the correct place because the car will spring back slightly wen you release the pressure.
Be sure you cut through the chassis stiffening before trying to push the car back. If you don't weaking the car you will just push damage in the car someplace else.
Good luck!
sean_v8_914
Feb 18 2010, 09:30 AM
yup. show teh good chassis doctor your set up, bracing used, jack stand set up. how did you support the car.
rick 918-S
Feb 19 2010, 12:31 AM
I'm like 400 miles from you. (6 hrs) But I have a full dance card or I would gladly come down to help. Show us a couple photos maybe we can help figure out this puzzle.
ghuff
Feb 19 2010, 09:26 AM
Pics. You can recover from this.
Eric_Shea
Feb 19 2010, 10:39 AM
http://www.914world.com/specs/bodydims.phpFind out where you are. Then you'll know where to go.
Krank
Feb 19 2010, 10:57 AM
Has anyone tried bonding stiffner panels in with the panel adhesives now available?
yeahmag
Feb 19 2010, 11:01 AM
That's a really interesting idea...
Katmanken
Feb 19 2010, 12:35 PM
Wouldn't do it.
They are designed for adhering non-structural body parts. They require really clean non-rusty metals, our are cars are old and rusty, and the rust never sleeps.
I can guarantee that if a rust bubble forms under a glue joint that the pressure from the growing rust cell is so large that it will delaminate the joint. Might take time, but a structural use would fail just when you don't want it- ie under a cornering load.
There are stuctual aircraft adhesives, but they work on clean aluminum.
Rod
Feb 19 2010, 02:41 PM
I can't offer help as I haven't been here, But I feel for you
With the advise and expertise here I'm sure you'll get it sorted though..
Cut those slits cut..
turnaround89
Feb 20 2010, 01:07 AM
So the windshield frame has come back towards the targa bar, which would explain why the pasenger door hangs low at the back. the measurement is about 1/8" off on each side. Right now i am trying to locate someone around illinois that has a frame rack and seeing what they can do. I don't want to cut anything until i get that opinion. I have ideas on how to fix it, however, to have a professional get the car dead straight is what i would rather have then me trying to pull this off. Anyone know of a place that can straighten out the frame?
At first i didn't think you could straighten a unibody car on a frame rack, but apparently its possible...just gotta find someone that can do it for me or give me their opinion.
Dave_Darling
Feb 20 2010, 02:46 AM
Brad Mayeur at 914 Limited should have some idea of where you can find a rack for the car.
--DD
rick 918-S
Feb 20 2010, 07:31 AM
QUOTE(Dave_Darling @ Feb 20 2010, 02:46 AM)
--DD
I used to have a Cellette. That would be the best way.
turnaround89
Feb 20 2010, 11:24 AM
I have no problems towing the car to have it fixed, if i have to tow it 4 hours somewhere, i am fine with that. as long as it gets done correctly. The thing i don't understand is, since the car bowed into itself, how does a machine fix that?
Eric_Shea
Feb 20 2010, 11:35 AM
Very powerful hydraulics. You may still need to make some cuts as recommended.
Andy can give you a very thorough explaination. His car was tweeked and "then" a cage was welded in. When he decided to have it fixed, the cutting of the cage "really" told the story of how far out they can be and what can be done to fix them properly. There's a picture here somewhere of that cut and a detailed thread on that fix.
Search (cause I'm to lazy to do it for you).
Eric_Shea
Feb 20 2010, 11:44 AM
Also, that window frame doesn't really do "jack" for measurement purposes. I can bent one of those easily by hand. You'll get a bunch of various windshield frame measurements here that are probably 1/4" off. There "is" a standard top frame measurement BUT, get the proper jam measurements first and then worry about the frame.
Hit that link I sent you and get door frame measurements as Rick suggested.
gopack
Feb 20 2010, 11:52 AM
I just did a Google search for "celette bench shop" and one of the first hits was this one.
celette benchFrom that web site:
Click to view attachmentLooks like the best posible place to start! Even has 914 content and I didn't even include that in the search criteria!
P.S. i am just up the road from you in Madison (for now). If you ever need a hand (I'm not that useful) with a project taht requires more than 2 hands, give me a PM throught the site!
jcambo7
Feb 20 2010, 07:46 PM
QUOTE(gopack @ Feb 20 2010, 11:52 AM)
Thats cool!
rick 918-S
Feb 20 2010, 08:23 PM
That link is awsome! Read the post on the page. A Cellette rep posted is number and states he is in Lombard IL. About 75 miles from Rockford. Call him. He will know where the Cellette shops are.
turnaround89
Feb 21 2010, 10:24 PM
What makes the celette better than othe racks? Also, is there anything that will need to be removed from the car, bumpers, suspension, etc? Id like to take the car there as a rolling chassis that way its easier to get it on the trailor. the pictures show the car as just a shell, i was hoping i could leave the suspension on.
rick 918-S
Feb 21 2010, 10:46 PM
QUOTE(turnaround89 @ Feb 21 2010, 10:24 PM)
The Cellette is a fixture type bench. The one in the photos does not show the fixtures. They are using a lazer to check the car. It seems as though the Cellette rep was offering the shop the option of renting the proper fixtures.
I'm kind of under the impression the shop in that link is selling their service as a Porsche repair shop and showing the Cellette bench but doesn't rent the fixtures when they do chassis work.
Here is a link to Sir Andy's severly bent chassis. This was repaired on a Cellette with proper fixtures. I don't know what it cost him but this is how you fix a 914. Yes you will need to drop the suspension for the fixtures.
http://www.914world.com/bbs2/index.php?sho...c=92489&st=
Feb 21 2010, 11:15 PM
Lots more pix ...
http://www.914world.com/bbs2/index.php?showtopic=52631You can rent the 914 specific fixtures for the celette bench. However, there's only two or 3 distribution centers left in the whole US that still have them.
Andy
Jeff Hail
Feb 21 2010, 11:30 PM
The shop in the photos is Ed Palmer's. Aka EPR (Ed Palmer Racing) Eddy is first rate. He opened a second shop dedicated to Porsche only. I would recommend him in a heartbeat. How many shops have two 917's in process other than Gunnar?
The vehicle is setup on the Cellette in preparation for correction. The Genesis laser measuring system is accurate to 1mm. The Cellette hard fixtures are accurate to 3mm. Between the two systems you are going to get as perfect as can be. If perfect existed I'd date it!
A little history here: Ed has been doing this as long as I have. Excluding the marital issues Ed eats , breathes and nightmares Porsches. Ed has produced some of wildest German monsters that any other shop can come up with. Ed has also produced some of the most perfect restorations I have seen.
Funny thing. My car was given to me by Tony Davis who worked for Ed for many years. Both go back to pre Mitcom days. Yes thats how long both have been in the business. I feel ancient now!
Very few shops own their own fixtures. Most rent them from Eurocar. Why buy the cow when you can get the milk for free?
turnaround89
Feb 21 2010, 11:32 PM
Sir andy - if you don't mind me asking, how much did it cost to have the car puton the rack and be aligned?
Feb 21 2010, 11:51 PM
QUOTE(turnaround89 @ Feb 21 2010, 09:32 PM)
Well, that's hard to say.
I did two cars at once. The red car took one day, the black/yellow car took 3 days.
For both cars and 4 full days of labor plus renting the Celette fixtures, my total bill was somewhere around $3000, if i recall correctly ...
Andy
turnaround89
Feb 22 2010, 12:18 AM
does the place doing the chassis alignment rent the fixtures or is that something i have to locate?
Feb 22 2010, 12:26 AM
QUOTE(turnaround89 @ Feb 21 2010, 10:18 PM)
In my case, Scott the owner of the body shop has lots of experience working on 914s (He owns two).
The way it works is that the body shop owns the Celette bench and they rent the fixtures from Celette whenever they need them. The shop took care of all that.
Getting the fixtures took a few days as there's only one Celette distributor left here on the west coast that still has the 914 fixtures.
Andy
rick 918-S
Feb 22 2010, 12:56 AM
QUOTE(turnaround89 @ Feb 22 2010, 12:18 AM)
I'd just call this guy. I'm sure he can tell you which shop in your area can bench your car.
Greg Fritz
Sales and Technical Support
630-396-6100 ext 6170 Office
630-495-4078 Fax
www.celette-na.com
turnaround89
Feb 22 2010, 11:54 AM
Found a body shop in my area with a celette bench, made a call and the owner said that fixing the car wouldn't wouldn't happen for under 5000, more towards 10000....im not paying that kind of money to fix a 3000 car, no matter the sentimental value i have in it. Time to find a shell or fix what i got.
rick 918-S
Feb 22 2010, 12:12 PM
QUOTE(turnaround89 @ Feb 22 2010, 11:54 AM)
That's pure bullshit. They just don't want to deal with it. I am working on tracking down a Cellette bench in town here. I just spoke with a guy that used to own one. He sold it to another shop here in town. I have a call into them now. (small shop with a answering machine)
I placed a call to the Cellette rep and left him a voice mail as well. What a bunch of crap!
BTW, Fixture rental used to be 300.00- 450.00 shipped.
rick 918-S
Feb 22 2010, 01:08 PM
QUOTE(rick 918-S @ Feb 22 2010, 12:56 AM)
Greg Fritz
630-495-4078 Fax
www.celette-na.com
I had a conversation with a Cellette rep. He is emailing info about the fixture availability, location and cost. I can either get you hooked up with the local shop or if they are tired of the old Cellette collecting dust in the corner I may just purchase the thing.
This will happen whether you ever fix your car or not. I have The raspberry car with a missing front clip and Sandy's I'm picking up in Cali in like two weeks. It took a hit to the front.
Your inquiry just prompted me to do something I have been wanting to do for a long time anyway.
Feb 22 2010, 01:16 PM
QUOTE(rick 918-S @ Feb 22 2010, 11:08 AM)
If you do, don't forget to make a 'backup copy' of the fixtures ...
Andy
carr914
Feb 22 2010, 01:35 PM
Turnaround, What happened to the pictures you were going to post?
turnaround89
Feb 22 2010, 02:23 PM
the pictures were on an external hard drive which makes a weird clicking noise when it starts up, the computer doesn't recognize it anymore...been going on for a couple weeks or so, my cousin is taking a look at...hopefully he can get the files off of it.
Anyway, the guy i talked to that has the celette bench has worked on multiple 911's, and seemed to know what he was talking about. His idea was to pull the whole car apart again and leave it on the frame rack and then reweld all the stuff back into the car. Lots of time right there. I made the floor pans and inner longs myself, and i really don't want to have to completely undo everything i just did. I don't mind cutting slots into the longs, but taking everything back out. no thanks
rick 918-S
Feb 22 2010, 02:34 PM
QUOTE(turnaround89 @ Feb 22 2010, 02:23 PM)
No need to rip apart all your work. It doesn't matter that you made your own pans and inner longs. The Cellette works off the suspension pickup points not the floor or longs. I suspect the cowl is leaning back which would cause the doors to sag at the rear. This would put the front most suspension pickup points of the car high and out of line. Should be able to bolt on the check sets (four center most fixtures) and find the issue. I would say it would be a matter of vertical cuts through your longs, check the upper body diamensions and adjust the car.
turnaround89
Feb 22 2010, 04:47 PM
right now were beginning to pull apart portions of the car, to get correct measurements. the front suspension is gonna get pulled off today, and well keep measuring to see where the car is off.
rick 918-S
Feb 22 2010, 05:51 PM
I heard back from the shop. I really couldn't read the guy. I asked him if he was interested in selling the bench. He said he would think about it. I asked him if he was interested in fixing your car. He said he would think about it.
Ok, but he did tell me that the local frame and axle guy has the second design Cellette bench that only requires the top section of the redsigned fixtures, It's the MZ model. Shipping cost for the fixtures are less because the tops come in a suitcase not a friggin shipping crate. The only thing is there may not be fixtures for the older chassis'. I'm still checking.
Feb 22 2010, 05:53 PM
QUOTE(rick 918-S @ Feb 22 2010, 03:51 PM)
I don't get it...
Think about it ...
