| turnaround89 |
Feb 17 2010, 08:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
| SirAndy |
Feb 17 2010, 08:52 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,517 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
went to test fit the passenger door and it won't even come close to shutting If the door is off in the up/down direction, simply open the door and grab the back and slowly pull it up until it lines up ... That's how the body shop would fix it. (IMG:style_emoticons/default/shades.gif) Andy |
turnaround89 My chassis twisted hardcore Feb 17 2010, 08:04 PM
nykthebartender How much is way off? You can shim the door hinges ... Feb 17 2010, 08:24 PM
scotty b If the latch is out, how does the door line up wit... Feb 17 2010, 08:26 PM
rick 918-S :ttiwwp: Feb 17 2010, 08:29 PM
yeahmag Yeah... Take the striker out and close the door. S... Feb 17 2010, 08:32 PM
J P Stein I did something similar wheb installing my cage. W... Feb 17 2010, 08:33 PM
bobhasissues What were you welding?
Engman kit
Clamshells
Other... Feb 17 2010, 08:54 PM
McMark :agree: we need a bunch more info/pics. Feb 17 2010, 09:31 PM
turnaround89 I welded in clamshells over the longs and also put... Feb 17 2010, 10:23 PM
davesprinkle That sucks. The only real option is to cut a few ... Feb 17 2010, 11:00 PM
turnaround89 the weirdest part is that the door hangs low at th... Feb 17 2010, 11:25 PM
davesprinkle
the weirdest part is that the door hangs low at t... Feb 17 2010, 11:41 PM
rick 918-S Don't bend the door! Fix the chassis. If y... Feb 18 2010, 08:21 AM
sean_v8_914 yup. show teh good chassis doctor your set up, bra... Feb 18 2010, 09:30 AM
rick 918-S I'm like 400 miles from you. (6 hrs) But I hav... Feb 19 2010, 12:31 AM
ghuff Pics. You can recover from this. Feb 19 2010, 09:26 AM
Eric_Shea http://www.914world.com/specs/bodydims.php
Find o... Feb 19 2010, 10:39 AM
Krank Has anyone tried bonding stiffner panels in with t... Feb 19 2010, 10:57 AM
yeahmag That's a really interesting idea... Feb 19 2010, 11:01 AM
kwales Wouldn't do it.
They are designed for adherin... Feb 19 2010, 12:35 PM
Rod I can't offer help as I haven't been here,... Feb 19 2010, 02:41 PM
turnaround89 So the windshield frame has come back towards the ... Feb 20 2010, 01:07 AM
Dave_Darling Brad Mayeur at 914 Limited should have some idea o... Feb 20 2010, 02:46 AM
rick 918-S
Brad Mayeur at 914 Limited should have some idea ... Feb 20 2010, 07:31 AM
turnaround89 I have no problems towing the car to have it fixed... Feb 20 2010, 11:24 AM
Eric_Shea Very powerful hydraulics. You may still need to m... Feb 20 2010, 11:35 AM
Eric_Shea Also, that window frame doesn't really do ... Feb 20 2010, 11:44 AM
gopack I just did a Google search for "celette bench... Feb 20 2010, 11:52 AM
jcambo7
I just did a Google search for "celette benc... Feb 20 2010, 07:46 PM
rick 918-S
I just did a Google search for "celette benc... Feb 20 2010, 08:23 PM
turnaround89 What makes the celette better than othe racks? Al... Feb 21 2010, 10:24 PM
rick 918-S
What makes the celette better than othe racks? A... Feb 21 2010, 10:46 PM
SirAndy Lots more pix ...
http://www.914world.com/bbs2/in... Feb 21 2010, 11:15 PM
Jeff Hail The shop in the photos is Ed Palmer's. Aka EPR... Feb 21 2010, 11:30 PM
turnaround89 Sir andy - if you don't mind me asking, how mu... Feb 21 2010, 11:32 PM
Sir andy - if you don't mind me asking, how m... Feb 21 2010, 11:51 PM
turnaround89 does the place doing the chassis alignment rent th... Feb 22 2010, 12:18 AM
does the place doing the chassis alignment rent t... Feb 22 2010, 12:26 AM
rick 918-S
does the place doing the chassis alignment rent t... Feb 22 2010, 12:56 AM
rick 918-S
does the place doing the chassis alignment rent ... Feb 22 2010, 01:08 PM
Your inquiry just prompted me to do something I h... Feb 22 2010, 01:16 PM
turnaround89 Found a body shop in my area with a celette bench,... Feb 22 2010, 11:54 AM
rick 918-S
Found a body shop in my area with a celette bench... Feb 22 2010, 12:12 PM
carr914 Turnaround, What happened to the pictures you were... Feb 22 2010, 01:35 PM
turnaround89 the pictures were on an external hard drive which ... Feb 22 2010, 02:23 PM
rick 918-S
the pictures were on an external hard drive which... Feb 22 2010, 02:34 PM
turnaround89 right now were beginning to pull apart portions of... Feb 22 2010, 04:47 PM
rick 918-S I heard back from the shop. I really couldn't ... Feb 22 2010, 05:51 PM
:WTF: I don't get it...
Think about it ... ... Feb 22 2010, 05:53 PM
dr914@autoatlanta.com
I braced the chassis, but obviously not enough. ... Feb 22 2010, 06:14 PM
turnaround89 Id have to tow the car down to georgia, and that w... Feb 22 2010, 06:38 PM
scotty b Rick, how about getting access to the one you know... Feb 23 2010, 06:57 PM
r_towle B)-->
rick 918-S B)--><div class='quotetop'>QUOTE... Feb 24 2010, 12:04 AM
shaggy how thick were the plates you welded on?
regardles... Feb 24 2010, 12:23 AM
rick 918-S I'm near a deal on the Celette. :shades2: Feb 25 2010, 06:28 PM
turnaround89 so heres the plan that we finally came up with. M... Feb 25 2010, 07:04 PM
rick 918-S
so heres the plan that we finally came up with. ... Feb 25 2010, 07:10 PM
sixnotfour Rick , I hope you get a bench ,
AArron @ Fat Six h... Feb 25 2010, 09:25 PM
9146986 I have an old Blackhawk bench, that I'm nearly... Feb 26 2010, 09:03 AM
rick 918-S
I have an old Blackhawk bench, that I'm nearl... Feb 26 2010, 10:17 AM
9146986 Thanks Rick! I felt kinda stupid after my pos... Feb 26 2010, 12:40 PM
9146986 Didn't someone copy the fixture dimensions in ... Feb 26 2010, 12:46 PM
Didn't someone copy the fixture dimensions in... Feb 26 2010, 03:48 PM
turnaround89 update: the drivers side door fits properly, shimm... Feb 26 2010, 03:56 PM
rick 918-S
update: the drivers side door fits properly, shim... Feb 26 2010, 07:02 PM
turnaround89 that is exactly what my passenger side door looks ... Feb 26 2010, 10:41 PM
rick 918-S Here's another crude sketch. I assume you used... Feb 26 2010, 11:21 PM
turnaround89 what your saying is fixing the door, should also f... Feb 26 2010, 11:49 PM
rick 918-S
what your saying is fixing the door, should also ... Feb 27 2010, 08:02 AM
turnaround89 I want to give a big thanks to everyone that helpe... Mar 4 2010, 02:41 PM
rick 918-S So tell us what you did! :sawzall: :smash: :... Mar 4 2010, 03:57 PM
drive-ability I second that above request :agree: :smash: Gre... Mar 4 2010, 06:14 PM
turnaround89 i did exactly what rick told me to do, i used a bo... Mar 4 2010, 06:21 PM
rick 918-S
i did exactly what rick told me to do, i used a b... Mar 4 2010, 06:36 PM
Jon Fernandes :trophy: Mar 4 2010, 06:27 PM
turnaround89 Once again a BIG THANK YOU to everyone that has he... Mar 4 2010, 08:10 PM
markb :beer2: Mar 4 2010, 10:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th September 2026 - 08:37 PM |
