Targa seal install?, How to get it in right. Any tricks? |
JRust |
Feb 20 2010, 01:28 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay so I am ready to install my new windshield targa seal. I started to feed it down the drivers side & only get a few inches down before it doesn't want to feed. I don't want to put anything on there lube wise that might degrade the seal. So what do you use?
Also any other tricks on how you did yours? Does that screw come from under or over. Damned if I can remember (IMG:style_emoticons/default/confused24.gif) |
xperu |
Feb 20 2010, 01:52 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
Okay so I am ready to install my new windshield targa seal. I started to feed it down the drivers side & only get a few inches down before it doesn't want to feed. I don't want to put anything on there lube wise that might degrade the seal. So what do you use? Also any other tricks on how you did yours? Does that screw come from under or over. Damned if I can remember (IMG:style_emoticons/default/confused24.gif) I used silicone spray, there are places/spots on the aluminium trim that were knocked in by the factory that I bent back out and it went in pretty easy. Mike |
dr914@autoatlanta.com |
Feb 20 2010, 02:00 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Okay so I am ready to install my new windshield targa seal. I started to feed it down the drivers side & only get a few inches down before it doesn't want to feed. I don't want to put anything on there lube wise that might degrade the seal. So what do you use? Also any other tricks on how you did yours? Does that screw come from under or over. Damned if I can remember (IMG:style_emoticons/default/confused24.gif) I used silicone spray, there are places/spots on the aluminium trim that were knocked in by the factory that I bent back out and it went in pretty easy. Mike excellent advice except silicone grease is the best! Make sure you stretch it out a bit before installing laterally. The two blocks on each end need to face directly backwards, not at all inwards, and bump against the top side seals. That is why the stretching. The factory seals are a little short across the top because of the stretch steel inside of them |
Lo-Fi Version | Time is now: 11th June 2024 - 10:53 AM |
