Rear view mirror mount removal, Solvent?? |
Elliot Cannon |
Feb 20 2010, 03:34 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I just installed a BMW rear view mirror. Isn't there some sort of solvent to remove the mirror mount that's glued on?
Attached image(s) |
dr914@autoatlanta.com |
Feb 20 2010, 03:37 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I just installed a BMW rear view mirror. Isn't there some sort of solvent to remove the mirror mount that's glued on? The original on the car was stuck with a patch that comes off with a razor blade. If mirror glue was used usually a razor blade started under it will lift the residue off. |
rick 918-S |
Feb 20 2010, 04:46 PM
Hey nice rack! -Celette Group: Members Posts: 20,494 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I just installed a BMW rear view mirror. Isn't there some sort of solvent to remove the mirror mount that's glued on? The original on the car was stuck with a patch that comes off with a razor blade. If mirror glue was used usually a razor blade started under it will lift the residue off. Heat gun and a razor blade. Or you could just (IMG:style_emoticons/default/smash.gif) then replace the winsheild.. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 11:52 PM |
