rear axle- removal, trying to inspect cv joints |
eyecolor |
Feb 21 2010, 02:32 PM
Eyecolor Group: Members Posts: 80 Joined: 15-August 08 From: Wilmington,DE Member No.: 9,425 Region Association: None |
I have disconnected the trans side when I dropped the engine. Now I want to take the axle off to inspect the CV joints.
I have removed the 4 bolts from the hub side but the unit is still fighting me to come out. I did see the pins holding the other side in and figured it just took some force. After running out of force, I checked the Haynes manual and it seems to say I need to take off the large central nut and cotter pin on the other side. Before I go this route, any advice? Thanks. George Wilmington,DE |
underthetire |
Feb 21 2010, 02:51 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I have disconnected the trans side when I dropped the engine. Now I want to take the axle off to inspect the CV joints. I have removed the 4 bolts from the hub side but the unit is still fighting me to come out. I did see the pins holding the other side in and figured it just took some force. After running out of force, I checked the Haynes manual and it seems to say I need to take off the large central nut and cotter pin on the other side. Before I go this route, any advice? Thanks. George Wilmington,DE Yes, cotter pin, and large nut, then the axles pull out. DONT roll the car without the axles in or you will damage the wheel bearings. I would think it's the easiest way to get the outboard CV's apart. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:19 PM |
