scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
I started cutting the holes in Mikes car for the oil tank and wanted to check on the oil line hole. Obviously by measurements I have marked the correct spot but this seems like a REALLY awkward spot to run a line. I wanted someone(s) confirmation it is correct and a pic of how the oil lines are run would be great (IMG:style_emoticons/default/smile.gif) Also where/how does the other line run ?
Attached image(s) ![]() ![]() |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
You will find that the oil fitting going to that one just fits. And I mean JUST fits. Much easier to hook that one up with the engine out. Depending how you're running the lines you may have to cut another hole straight out from that one. That's how I did mine. Ran the -12 hose in front of the engine mount over to the tank. It's tight but once installed looks neat and tidy. Good luck.
Lo-Fi Version | Time is now: 11th June 2024 - 05:11 AM |
