6 oil tank install ? |
scotty b |
Feb 21 2010, 12:12 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I started cutting the holes in Mikes car for the oil tank and wanted to check on the oil line hole. Obviously by measurements I have marked the correct spot but this seems like a REALLY awkward spot to run a line. I wanted someone(s) confirmation it is correct and a pic of how the oil lines are run would be great (IMG:style_emoticons/default/smile.gif) Also where/how does the other line run ?
Attached image(s) |
IronHillRestorations |
Feb 21 2010, 03:48 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
There's a flat rubber gasket ring that fits over the lower spigot, and then and a large nut secures the bottom fitting after the tank is installed.
There's two different nylon spacers for the M8 studs, one goes on the stud before installing, and the other goes on the stud after the tank is in place. There's also a large rubber boot and a snap ring for the filter console hole. If I can get over to the shop this evening I'll take some pics of the factory tank hardware. |
Lo-Fi Version | Time is now: 11th June 2024 - 02:19 AM |
