My chassis twisted hardcore |
turnaround89 |
Feb 17 2010, 08:04 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
turnaround89 |
Feb 22 2010, 12:18 AM
does the place doing the chassis alignment rent the fixtures or is that something i have to locate?
rick 918-S |
Feb 22 2010, 12:56 AM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
does the place doing the chassis alignment rent the fixtures or is that something i have to locate? I'd just call this guy. I'm sure he can tell you which shop in your area can bench your car. Greg Fritz Sales and Technical Support 630-396-6100 ext 6170 Office 630-495-4078 Fax www.celette-na.com |
Lo-Fi Version | Time is now: 10th June 2024 - 06:23 AM |
