turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Rick, how about getting access to the one you know of long anough to get some god pictures and measurements. There isn;t that much there, and a bench could easily be replicated by you, or any one of us with the tools and experience. I know, I for one would have enough use to build one. I would imagine Perry might be interested too (IMG:style_emoticons/default/confused24.gif) The the only issue is the fixtures........ (IMG:style_emoticons/default/idea.gif)
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
(IMG:style_emoticons/default/cool.gif)--><div class='quotetop'>QUOTE(scotty b @ Feb 23 2010, 06:57 PM)
![]() Rick, how about getting access to the one you know of long anough to get some god pictures and measurements. There isn;t that much there, and a bench could easily be replicated by you, or any one of us with the tools and experience. I know, I for one would have enough use to build one. I would imagine Perry might be interested too (IMG:style_emoticons/default/confused24.gif) The the only issue is the fixtures........ (IMG:style_emoticons/default/idea.gif) [/quote] Here's what I know about the bench. The early Celettes have a machined deck like decking a cylinder head. The fixtures bolt to the cross beams. The early fixtures are like the ones in Sir Andy's photos. The later model Celettes have a standard upright fixture set that is part of the bench when you purchase it. The fixtures bolt to the top of the uprights. This only requires a large suit case of tops not and entire crate of parts. That was the drawback of the old bench was shipping the fixtures around. I know there are 914 fixtures for the early bench. I haven't verified ther are fixtures for the redsigned bench. Sorry for hi-jacking your thread. I should have started a new one. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:17 AM |
