Methanol Injection Turbo Intercooler GURU needed, Do i really need intercooler?? |
budman5201 |
Feb 22 2010, 09:47 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
I was considering pure meth injection with a full tune again, but eliminating my intercooler. (PURPOSE is to run normal gas and fill up on 1 gallon of meth every 2-3 tanks.) Also less weight, intercooler, water lines, pump, front heat exchanger, etc...(about 42 lbs total)
please chime in guys that have installed Meth injection on their turbo or supercharged cars and what is the temperature drop? Can the temp drop be close to my intercooler temp drop? so i wont need the intercooler? Can the PURE meth injection drop the temp close and have the octance boost make up for the difference in fuel requirement so i can eliminate my need for intercooler? I run 110 octance right now when i am at 19 lbs boost I run 91 octane when only 12 lbs boost , both scenarios no prob with engine. KNOWLEDGE of direct experience needed before i take this step....thanks guys!! oh also just a note, i am barely on boost once i hit it. ONce i start to hit it, i almost to need to slow down.....DAMN speed limit. 1-2.5 secs each gear, except when on freeway. 5-8 secs on boost at 65mph-95mph |
Andyrew |
Feb 25 2010, 07:34 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
But why go through that expense? An intercooler is just a great idea.. What happens if your meth system fails? You would probably blow your motor.
Go post on the Evo forums, theres a bunch of guys that run meth there. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:22 AM |
