Stock Passenger Door Mirror, Where do they mount?? |
aircooledtechguy |
Feb 26 2010, 10:01 AM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I scored me a passenger door mirror today on CL. Now I need to get ready to mount it.
1. Do all the cars have the captured nuts under the door skin similar to the drivers door that just need to be drilled out through the skin?? If so, I assume drilling from the inside of the door out is the way to do this?? 2. If not and I will have to add my own nuts to the screws, does anyone have the correct location I will need to locate it so it's usable?? I know it needs to be aft of the drivers side a bit Thanks!! |
dr914@autoatlanta.com |
Feb 26 2010, 10:05 AM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I scored me a passenger door mirror today on CL. Now I need to get ready to mount it. 1. Do all the cars have the captured nuts under the door skin similar to the drivers door that just need to be drilled out through the skin?? If so, I assume drilling from the inside of the door out is the way to do this?? yes and yes remove the door panel and push a sharp punch upward through the two tapped mirror holes, which will make small dents on the door skin and then you can drill and tap. I guess that you do not have the "TECH TIPS 700" book? 2. If not and I will have to add my own nuts to the screws, does anyone have the correct location I will need to locate it so it's usable?? I know it needs to be aft of the drivers side a bit Thanks!! |
Lo-Fi Version | Time is now: 7th June 2024 - 06:23 AM |
