My chassis twisted hardcore |
turnaround89 |
Feb 17 2010, 08:04 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
turnaround89 |
Feb 26 2010, 10:41 PM
that is exactly what my passenger side door looks like when its on...that description worked perfectly, thank you. Would the method i described for the targa top going back into place work? Jack the opposing side so the car twists back into alignment.
When you show, make the cut in the metal, should i just make a slot on the bottom and follow it up around the corners or cut the hole thing all the way around? Thanks for all the help!!!!!!!!!!!! |
Lo-Fi Version | Time is now: 10th June 2024 - 03:02 PM |
