Air Deflector, For my trailer |
Randal |
Feb 27 2010, 12:28 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I just bought an air deflector that is 64" by 34" and will be bolting it to my trailer in front of the tire rack. You've seen these deflectors on big diesel trucks, kind of looks like a big snow board.
I might have to move the tire rack back 6 inches to get the rake I want, but here is my question? Is it better to mount it low or high? I can mount it on the trailer A frame, directly behind the triangle aluminum box, but I'd have to move the tire rack back at least 6". I can mount it next to the back lip (cover) of the aluminum box but will still have to move the tire rack. In any event, where will I get the best air flow to help mileage? |
URY914 |
Feb 27 2010, 04:46 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,883 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Higher would be better as it will smooth out the air over the top of the car.
Randal |
Feb 28 2010, 12:08 PM
Higher would be better as it will smooth out the air over the top of the car. I'll mount it high as you suggested and also leaning back as in the picture. Think moving the tire rack back 6 inches would be just about right. Of course I'd still have to figure out where to put the tank. Maybe weld the rings to the front cross bar of the trailer. Yea, that might work, but it would be hell to get the (heavy and awkward) tank into the rings without any real flat surfaces except the top 2" of the cross bar. Or I could get rid of the trailer box, which would be the easiest of all solutions. Or i could mount the deflector right where it is shown in the picture, then use removable pins on the bottom so I can just lift it out of the way when I need to get into the box. |
Lo-Fi Version | Time is now: 29th May 2024 - 12:12 AM |
