> Ultra effecient combustion cars, under 1.5 litre, thoughts, pics, comments, designs, concepts
pete-stevers
post Feb 25 2010, 12:38 PM
saved from fire!
Given todays economic climate, possible scaricity of fuel, and of course just the raw challenge of building a car with high mpg,
we should have a thread on cars of this nature, in production,prototypes,homebuilts, concepts and pictures.
( I wish i had the time and energy to build a car with a sub 1 litre engine, and maybe one day i will)
but lets keep it to combustion power, for now
underthetire
post Mar 1 2010, 06:18 PM
I don't understand why everyone thinks low RPM=better mileage. You need more throttle to keep speed then. More-throttle=less vacuum=less efficiency. Think somewhere I read you want to be in cruise speed at 60% range of your max HP RPM. You would need to build a super torqy, low RPM engine to gain anything. I remember going from 4:11 to 4:88 gears on my Toyota PU and the mileage went up about 5 MPG.
Dave_Darling
post Mar 2 2010, 05:15 PM
914 Idiot
QUOTE(underthetire @ Mar 1 2010, 04:18 PM) *
Because, in general, it's true. Higher RPM for a given speed (i.e., shorter gearing) means more combustion events per mile. That means more fuel burned per mile. This does break down at very low RPMs where the engines get very inefficient, but that range is usually below 2000 RPM.
Check some BSFC maps. No, not the single-line curve we've seen before, I mean a full map of torque vs. RPM (or nearly equivalently, BMEP vs. RPM) plotting BSFC for the full range of those two. You'll see that the minimum consumption is around 2000-2500 RPM and 70% throttle in most cases.
Now, just to confuse things further, remember that most cars need on the order of 10-20 HP to cruise at "freeway speeds" on a typical day. (You can reduce that required power by lowering your speed, by lowering your rolling resistance, by lowering your CdA, or some combination of all three.) So for steady-state cruising, the question becomes "what RPM does your car most efficiently generate 15 HP?" Which may not be the same as "where is the most efficient range of operation for the engine?"
It's an interesting subject, and the hypermiler and ecomodder crowds really have some pretty decent ideas of what is going on. Doing some research (or at least some reading) on http://ecomodder.com can provide more info, including instrumented repeatable real-world tests.
--DD
pete-stevers   Ultra effecient combustion cars, under 1.5 litre   Feb 25 2010, 12:38 PM
Jon Fernandes   Europe has always used small engine in small cars,...   Feb 25 2010, 12:52 PM
patssle   Europe has always used small engine in small cars...   Feb 25 2010, 01:09 PM
johannes   That was true in 1950 ...   Feb 26 2010, 06:18 AM
pbanders   The original Audi A2 was a remarkable car: http:/...   Feb 25 2010, 01:00 PM
underthetire   A guy here is putting a Turbo hyabusa 1300 in his ...   Feb 25 2010, 01:00 PM
RobW   I fully expect to convert my Dad's car to elec...   Feb 25 2010, 01:03 PM
6freak   Woodgas ...   Feb 25 2010, 01:11 PM
pete-stevers   Europe has always used small engine in small car...   Feb 25 2010, 01:11 PM
RJMII   I was reading some information on GDI (Gas Direct ...   Feb 25 2010, 01:14 PM
turboman808   I was reading some information on GDI (Gas Direct...   Feb 25 2010, 02:10 PM
kwales   More power in diesel fuel which equates to better ...   Feb 25 2010, 01:25 PM
rick 918-S   100hp factory rated 1.3L twin cam Suzuki Swift GTI...   Feb 25 2010, 01:34 PM
6freak   size matters in a car wreck ..theres more to life ...   Feb 25 2010, 01:36 PM
JJ914GT   That's an MG Midget. ( Oh, wait,.. this isn...   Feb 25 2010, 01:43 PM
Brett W   Can't tow 16K lbs with a 1.4litre toy. Don...   Feb 25 2010, 01:46 PM
wayne1234   We have a 08 Toyota Yaris it is 1.5 liter 106hp. c...   Feb 25 2010, 01:55 PM
Phoenix-MN   I started driving a 2005 Scion xB a few years ago ...   Feb 25 2010, 02:13 PM
wayne1234   As far as small not being safe, I believe it all m...   Feb 25 2010, 02:13 PM
Andyrew   A friend of mine has a 93 honda civic "lean b...   Feb 25 2010, 02:14 PM
davep   The best mileage of any car I've ever owned wa...   Feb 25 2010, 02:23 PM
pete-stevers   i wonder what jake could do to a 1.7 to make it ev...   Feb 25 2010, 02:34 PM
pbanders   FWIW, my commute car is a 2009 Honda Fit Sport, wi...   Feb 25 2010, 02:35 PM
RoninEclipse2G   There is a lot to be said for the guys that are dr...   Feb 25 2010, 02:35 PM
pete-stevers   How about the VW Polo, 1.3 G40? that would be a ni...   Feb 25 2010, 02:45 PM
Dave_Darling   Lean burn is no longer in favor because it produce...   Feb 25 2010, 02:47 PM
RobW   Lean burn is no longer in favor because it produc...   Feb 26 2010, 07:55 AM
messix   my get to work beater is a '95 geo metro, i dr...   Feb 25 2010, 02:53 PM
messix   talk about old cars new engines... i'd love to...   Feb 25 2010, 03:10 PM
patssle   My college car was a 1996 Chevy Beretta. A decent ...   Feb 25 2010, 03:17 PM
RoninEclipse2G   DD, that article on the AeroCivic got me thinking ...   Feb 25 2010, 06:17 PM
Gigamight   My favorite gas-sipper was my 92 Honda Civic VX. I...   Feb 25 2010, 06:43 PM
Todd Enlund   I think that a TDI 914 would be cool, and should b...   Feb 25 2010, 09:18 PM
Dr Evil   Someday I WILL do a respectable TDI into 914 conve...   Feb 26 2010, 12:12 AM
veltror   Diesels are vastly popular in most of Europe in...   Feb 26 2010, 04:42 AM
zymurgist   I could get 37 mpg in my RSX if I drove slower. I...   Feb 26 2010, 05:42 AM
johannes   This is the concept of the future. http://www.lore...   Feb 26 2010, 06:33 AM
zymurgist   One of my friends (who drives an RSX Type S) goes ...   Feb 26 2010, 07:28 AM
johannes   That's true but Diesel is also more efficien...   Feb 26 2010, 08:07 AM
Brett W   http://www.americanthinker.com/2010/02/con...fe_st...   Feb 26 2010, 08:21 AM
zymurgist   One of the reasons that diesel cars aren't all...   Feb 26 2010, 08:25 AM
Bleyseng   My 2003 1.8T Passat got 35-40 mpg without problem ...   Feb 26 2010, 08:35 AM
pete-stevers   Hey Geoff...good to see you!   Feb 26 2010, 01:13 PM
Dave_Darling   Interesting about the diesels in the UK. And I di...   Feb 26 2010, 03:15 PM
zymurgist   Ken, diesel is cheaper than supreme unleaded gaso...   Feb 26 2010, 05:47 PM
pete-stevers   Dave thanks for your contribution I am of the mind...   Feb 26 2010, 05:15 PM
Todd Enlund   Dave thanks for your contribution I am of the min...   Mar 1 2010, 05:12 PM
pete-stevers   I think the route i would go in a build up of this...   Feb 28 2010, 12:56 PM
pete-stevers   i wonder what jake could do to a 1.7 to make it e...   Feb 28 2010, 09:58 PM
Vacca Rabite   i wonder what jake could do to a 1.7 to make it ...   Mar 1 2010, 08:42 AM
johannes   It would not be too hard, but would cost a littl...   Mar 1 2010, 10:15 AM
Vacca Rabite   - Tall transmission gearing / In my opinion the 9...   Mar 1 2010, 10:20 AM
johannes   There was a thread about that where Jake explained...   Mar 1 2010, 06:22 AM
Brett W   There is nothing wrong with turning some rpm. My ...   Mar 1 2010, 01:31 PM
underthetire   I don't understand why everyone thinks low RPM...   Mar 1 2010, 06:18 PM
Dave_Darling   I don't understand why everyone thinks low RP...   Mar 2 2010, 05:15 PM
johannes   Low RPM means less friction that means better effi...   Mar 2 2010, 06:29 AM
- Lo-Fi Version Time is now: 8th July 2025 - 09:24 PM
