My chassis twisted hardcore |
turnaround89 |
Feb 17 2010, 08:04 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that.
turnaround89 |
Mar 4 2010, 06:21 PM
i did exactly what rick told me to do, i used a bottle jack, instead of the port-o-power, and pushed daigonally across the door jam. I had to cut both sides of the car at the same spot. When i cut the drivers side, all the stress was relieved and the car would move around in any way we wanted to. Along with jacking diagonally across the door jam we also pushed up from underneath, with another jack. At this point the targa top wouldn't fit correctly, but the doors shut. To get the top to fit, i placed a jack stand on the drivers side trailing arm mount. this pushed that corner of the car up, slightly rotating the car making the targa top fit way better then it did before. AFter everything was lined up how we wanted it, i started welding. switched sides this time, so the car wouldn't twist again. Got everything welded up, put the tires on and the car back on the ground and everything still works. I can now move onto the next project, bodywork and replacing the windshield. I actually managed to get the windshield out by myself. I have always wanted to redo that piece of vinyl thats right there underneath the windshield, so now is the best time to do it. And the seal that goes down there was as hard as a rock. I saved myself the 175 dollar of having someone else install the windshield, now i can spend it on a new lower seal
Lo-Fi Version | Time is now: 10th June 2024 - 04:23 AM |
