bag5rcg |
Member ![]() ![]() Group: Members Posts: 80 Joined: 20-February 06 From: Dallas, Ga Member No.: 5,607 ![]() |
Hi Gang,
Has anybody out there wired up an MSD 6AL to a 3.0 6 with a regulated alternator?....I am afraid to play too hard with it because I don't want to start burning up components (IMG:style_emoticons/default/blowup.gif) during the effort which would lead to chasing several problems rather than one. I also cannot get my car to do ANYTHING with the relay board attached (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/wacko.gif) ....I am playing with the idea of bypassing the relay board all together by replacing the female style plug (on the engine side) with a male style plug that would plug into the chassis plug directly (IMG:style_emoticons/default/idea.gif) .... Any thoughts, suggestions would be appreciated..This is the very last engineering hurdle in a 4 year restore/6 conversion Thanks |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
QUOTE No more relay board ... I used a conversion harness from Patrick Motorsports. It directly connects the engine harness to the body harness plug that normally goes to the relay board. Is that something I should get for my 3.0L that I am putting into the 6? |
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,585 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
QUOTE No more relay board ... I used a conversion harness from Patrick Motorsports. It directly connects the engine harness to the body harness plug that normally goes to the relay board. Is that something I should get for my 3.0L that I am putting into the 6? If your running carbs I wouldn't bother, the only connections on my carbed motor are to the alternator and the dizzy. If you're running CIS you might consider it if patricks even offers it. Andys motor is a motronic 3.6, so it makes more sense to use it on his application... |
Lo-Fi Version | Time is now: 16th June 2024 - 06:49 PM |
