Valve lash, With WEBCAM #494 |
jeffdon |
Mar 13 2010, 06:09 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Ran the 2056 on the stand for a last time to get the oil warm, and do the initial change, and get her ready for installation. Did another valve check. Which got me to thinking.
I am setting it to the spec that came with the cam, .006 for both exhaust and intake. Lift (.465) and duration (280 deg.) are the same for both valves. Question is, if exhaust valves expand more due to heat than intake, why does webcam recommend .006 for both? Why not .006 and .008 as is standard? It SEEMS to be running pretty well, but I know i have a good deal of fooling around with jets and such once its on the road and i can test her under load. At one point at about 3500 rpm it started firing back through No 4., but that was right about the time i was running out of gas in my temp. tank. I shut it off, and got a big pop and some flame out the tail pipe. I would really like address/double check anything now, as its way easier accesing things on the stands. |
Cap'n Krusty |
Mar 14 2010, 09:38 AM
The .008" number is specified ONLY for T4 engines with Sodium filled exhaust valves. All others use .006 for stock setups, or what the camshaft or pushrod manufacturer recommends.
The Cap'n |
jeffdon |
Mar 14 2010, 11:06 AM
The .008" number is specified ONLY for T4 engines with Sodium filled exhaust valves. All others use .006 for stock setups, or what the camshaft or pushrod manufacturer recommends. The Cap'n Hey Cap'n - So you would not go with the "run em loose" for break in advise??? |
Cap'n Krusty |
Mar 14 2010, 08:28 PM
The .008" number is specified ONLY for T4 engines with Sodium filled exhaust valves. All others use .006 for stock setups, or what the camshaft or pushrod manufacturer recommends. The Cap'n Hey Cap'n - So you would not go with the "run em loose" for break in advise??? I run'em where they're supposed to be, whatever that is for the particular application. After cranking for oil pressure with the plugs out, I run pushrod engines for 20-30 minutes at 1500-2000 RPM, then fine tune the carbs and timing before shutting it down and allowing it to cool down for 3-4 hours. I then check and adjust the valves before installing the engine. On FI engines I do the same thing, only in the car. The Cap'n |
Lo-Fi Version | Time is now: 1st June 2024 - 06:35 AM |
