> carb rebuild question, throttle bearings
tat2dphreak
post Mar 15 2010, 08:31 AM
stoya, stoya, stoya
ok, my set of weber 40s... they are old(built in the early 80s by his estimation). my mechanic cannot replace the throttle bearings and thus, they do not idle right once the engine gets warm, it's like they are always slightly "cracked" open, when warm.
is there a place that can rebuild these and make them "new" again? or is it time to start carb shopping?
fron what I understand, the new carbs have a plate on the front, and one on the back that can be removed to replace the throttle shaft bearings, but this set only has 1 plate, so the bearings are not replaced(at least by normal means)
tat2dphreak
post Mar 15 2010, 02:35 PM
stoya, stoya, stoya
(IMG:style_emoticons/default/huh.gif)
I will take it off one side when I get home, and report my findings... does it take a special shop/tool to replace these? I was told these were
pre-bearings... on the front there is not the springed piece as shown on the other carb... it's basically the same except it has a throttle stop, idle screw and throttle ear.
should these be repairable by moi? or just send them to Ace?
tat2dphreak   carb rebuild question   Mar 15 2010, 08:31 AM
Van   On my 44s, the bearing pops right out when you dri...   Mar 15 2010, 09:28 AM
tat2dphreak   yea, that's different than mine :) on this p...   Mar 15 2010, 09:37 AM
Vacca Rabite   Wayne, I think I have the same carbs that you do, ...   Mar 15 2010, 10:06 AM
ME733   ............Wayne.... are you trying to say that y...   Mar 15 2010, 10:12 AM
tat2dphreak   from my understanding, yes. I think... what I am r...   Mar 15 2010, 10:23 AM
Van   So, is there anything preventing you from removing...   Mar 15 2010, 10:28 AM
ME733   ..........Do you have a little mechanical aptitude...   Mar 15 2010, 10:31 AM
tat2dphreak   ..........Do you have a little mechanical aptitud...   Mar 15 2010, 10:37 AM
tat2dphreak   maybe I don't?! :confused: if there's...   Mar 15 2010, 10:33 AM
ME733   .........It is entirely possable that the "bu...   Mar 15 2010, 10:50 AM
tat2dphreak   .........It is entirely possable that the "b...   Mar 15 2010, 11:38 AM
rhodyguy   wayne, contact the folks at Air Cooled Enterprises...   Mar 15 2010, 11:09 AM
tat2dphreak   found a pic of the carb, specifially the back that...   Mar 15 2010, 02:07 PM
Van   Um... have you taken off that nut and looked behin...   Mar 15 2010, 02:18 PM
ME733   .........YEP.........take off the nutand washer......   Mar 15 2010, 02:33 PM
tat2dphreak   :huh: I will take it off one side when I get home...   Mar 15 2010, 02:35 PM
ME733   ...........well , you were told wrong.....Now arn...   Mar 15 2010, 02:41 PM
tat2dphreak   ok, well, here's the deal, ACE may not be cost...   Mar 15 2010, 03:06 PM
Van   I recently changed my bearings... They were only ...   Mar 15 2010, 03:31 PM
tat2dphreak   cool, where did you get the bearings? also, can on...   Mar 15 2010, 03:51 PM
Van   I say: give it a try yourself! I think you ca...   Mar 15 2010, 05:32 PM
tat2dphreak   the bearings looked ok, so I called wes, he replac...   Mar 15 2010, 09:13 PM
Van   What number (in that diagram I posted earlier) are...   Mar 15 2010, 09:20 PM
tat2dphreak   according to ACE, and Wes, they are somewhere in t...   Mar 15 2010, 09:30 PM
Mark Henry   I've made bushings before on my mini lathe but...   Mar 16 2010, 03:30 AM
ArtechnikA   Bieker can do throttle shaft bushings. I think he...   Mar 16 2010, 04:15 AM
Van   If the 40 IDFs are manufactured like the 44 IDFs (...   Mar 16 2010, 05:32 AM
ME733   If the 40 IDFs are manufactured like the 44 IDFs ...   Mar 16 2010, 07:28 AM
Van   where did you get the screws (diagram #40)for you...   Mar 16 2010, 11:43 AM
tat2dphreak   since the car is dry-docked, maybe I'll try to...   Mar 16 2010, 11:47 AM
Van   since the car is dry-docked, maybe I'll try t...   Mar 16 2010, 01:03 PM
tat2dphreak   thanks for the info, I'll keep everyone posted...   Mar 16 2010, 01:19 PM
tat2dphreak   ok, who said "linkage"? because it was...   Apr 3 2010, 02:31 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:28 AM
