| tat2dphreak |
Mar 15 2010, 08:31 AM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
ok, my set of weber 40s... they are old(built in the early 80s by his estimation). my mechanic cannot replace the throttle bearings and thus, they do not idle right once the engine gets warm, it's like they are always slightly "cracked" open, when warm.
is there a place that can rebuild these and make them "new" again? or is it time to start carb shopping? fron what I understand, the new carbs have a plate on the front, and one on the back that can be removed to replace the throttle shaft bearings, but this set only has 1 plate, so the bearings are not replaced(at least by normal means) |
| tat2dphreak |
Mar 16 2010, 11:47 AM
since the car is dry-docked, maybe I'll try to pull the shafts and check and see if the bearings are fitting tight... are there any "watchout" things that might keep me from getting it back together correctly?
| Van |
Mar 16 2010, 01:03 PM
Member ![]() ![]() Group: Members Posts: 199 Joined: 15-January 08 From: Hyde Park, NY Member No.: 8,571 |
since the car is dry-docked, maybe I'll try to pull the shafts and check and see if the bearings are fitting tight... are there any "watchout" things that might keep me from getting it back together correctly? It's pretty straight forward. Remember to be careful not to bend that throttle shaft - it's a bitch to straighten! That also goes for the end nuts. If you can, hold that round washer part (and the linkage arm at the other end) with pliers so you don't put a "twisting" motion on that shaft. When you put it together, remember the accelerator pump linkage... the first time I put a carb back together, I forgot it and had to pull the throttle shaft out again. When you put the butterflies back in, slide both into the shaft (they only go in 1 direction - on my 44s, the stamping (78 degrees) is visible from the bottom (if I recall). it'll be obvious if it's not right, because the screw holes won't line up. Anyhow, put the screws in loosely, make sure you "close" the throttle so the butterflies are seated properly in the bores, then tighten the screws. It might take a few tries - so be patient. When you get it right, they close with a most satisfying "snap"! Also, you can't see any light around the edges when you hold it up to the light and try to look through. Obviously, if you feel you need to force something, you might be doing it wrong - so stop and get a 2nd opinion. Let us know how it goes! Here are some pages you might find useful: http://www.rescue912.com/spider/WeberIDF_Rebuild/ http://www.aircooled.net/gnrlsite/resource...8idarebuild.htm |
tat2dphreak carb rebuild question Mar 15 2010, 08:31 AM
Van On my 44s, the bearing pops right out when you dri... Mar 15 2010, 09:28 AM
tat2dphreak yea, that's different than mine :)
on this p... Mar 15 2010, 09:37 AM
Vacca Rabite Wayne, I think I have the same carbs that you do, ... Mar 15 2010, 10:06 AM
ME733 ............Wayne.... are you trying to say that y... Mar 15 2010, 10:12 AM
tat2dphreak from my understanding, yes. I think... what I am r... Mar 15 2010, 10:23 AM
Van So, is there anything preventing you from removing... Mar 15 2010, 10:28 AM
ME733 ..........Do you have a little mechanical aptitude... Mar 15 2010, 10:31 AM
tat2dphreak
..........Do you have a little mechanical aptitud... Mar 15 2010, 10:37 AM
tat2dphreak
maybe I don't?! :confused: if there's... Mar 15 2010, 10:33 AM
ME733 .........It is entirely possable that the "bu... Mar 15 2010, 10:50 AM
tat2dphreak
.........It is entirely possable that the "b... Mar 15 2010, 11:38 AM
rhodyguy wayne, contact the folks at Air Cooled Enterprises... Mar 15 2010, 11:09 AM
tat2dphreak found a pic of the carb, specifially the back that... Mar 15 2010, 02:07 PM
Van Um... have you taken off that nut and looked behin... Mar 15 2010, 02:18 PM
ME733 .........YEP.........take off the nutand washer...... Mar 15 2010, 02:33 PM
tat2dphreak :huh:
I will take it off one side when I get home... Mar 15 2010, 02:35 PM
ME733 ...........well , you were told wrong.....Now arn... Mar 15 2010, 02:41 PM
tat2dphreak ok, well, here's the deal, ACE may not be cost... Mar 15 2010, 03:06 PM
Van I recently changed my bearings... They were only ... Mar 15 2010, 03:31 PM
tat2dphreak cool, where did you get the bearings? also, can on... Mar 15 2010, 03:51 PM
Van I say: give it a try yourself!
I think you ca... Mar 15 2010, 05:32 PM
tat2dphreak the bearings looked ok, so I called wes, he replac... Mar 15 2010, 09:13 PM
Van What number (in that diagram I posted earlier) are... Mar 15 2010, 09:20 PM
tat2dphreak according to ACE, and Wes, they are somewhere in t... Mar 15 2010, 09:30 PM
Mark Henry I've made bushings before on my mini lathe but... Mar 16 2010, 03:30 AM
ArtechnikA Bieker can do throttle shaft bushings. I think he... Mar 16 2010, 04:15 AM
Van If the 40 IDFs are manufactured like the 44 IDFs (... Mar 16 2010, 05:32 AM
ME733
If the 40 IDFs are manufactured like the 44 IDFs ... Mar 16 2010, 07:28 AM
Van
where did you get the screws (diagram #40)for you... Mar 16 2010, 11:43 AM
tat2dphreak thanks for the info, I'll keep everyone posted... Mar 16 2010, 01:19 PM
tat2dphreak ok, who said "linkage"?
because it was... Apr 3 2010, 02:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:26 AM |
