76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,734 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Well, after 3 trips back to the tire shop I have them balanced. You'll think this is nuts but try it. First let's give credit where it is due. I clicked on the link posted on aircooledtechguys signature and found this article on balancing tires with air ball bb's. $9 at Wally's and you have enough for 20 tires. It was listed under under "cheap tools" on his website. Basically you put 1.5 oz's in each tire and thats it. So the 3rd trip I took 4 bags weighed out at 1.5 ounces each with these plastic 6.5mm bb's and had the "tire dude" break the beads and insert the bb's. I got some funny looks but it seems to have worked. PS. These can't be used if you have a tire sealer additive in your tires, ever! He shows white balls in his article but I much preferred the competition red bb's.
http://aircooledtech.com/tools-on-the-cheap/balancing_beads/ |
wobbletop |
Member ![]() ![]() Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada ![]() |
From the "How it works page"
Why don't you have tire charts for cars, SUV's or minivans? We don't market to cars, SUV's or minivans due to the overall style of those tires, which are low and wide. This style of tire commonly exhibits varying degrees of lateral imbalance due primarily to the width. This type of inbalance can only be corrected with carefully placed wheel weights. So that means that while Dyna Beads should not be used as the sole balancing method for these tire types, they can be used as a supplemental method. Using a combination of weights and Dyna Beads results in higher tire mileage and a reduction, or elimination, of future rebalancing requiements. For the proper amount, click here. |
76-914 |
From the "How it works page" Why don't you have tire charts for cars, SUV's or minivans? We don't market to cars, SUV's or minivans due to the overall style of those tires, which are low and wide. This style of tire commonly exhibits varying degrees of lateral imbalance due primarily to the width. This type of inbalance can only be corrected with carefully placed wheel weights. So that means that while Dyna Beads should not be used as the sole balancing method for these tire types, they can be used as a supplemental method. Using a combination of weights and Dyna Beads results in higher tire mileage and a reduction, or elimination, of future rebalancing requiements. For the proper amount, click here. (IMG:style_emoticons/default/agree.gif) Well lucky for me that's what I did. Tire shop asked if they should leave the weights on and I said yes. I figured these beads were supplemental and if not I could remove the weights, myself. It's good to hear that no wear or damage results from this. |
Lo-Fi Version | Time is now: 1st July 2025 - 06:44 AM |
