Fuel pump location, on a 72 |
jeffdon |
Mar 18 2010, 04:57 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
My 72 never had the FI pump under the tank. Car is now carbed, and I am thinking of mounting my carter pump up front. Wheres the easiest place to find a keyed positive?
Also, fuel lines are original. With the pump in the engine bay, i figured that there was not much pressure on them, as the pump was operating to suck the fuel up the line. IF i put it up front, then there will be pressure on the supply lines. Am I creating a situation where leaks are more likely? |
TheCabinetmaker |
Mar 18 2010, 06:04 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Only 75/76 had fuel pump in front. Carbs? No advantage to moving it that I can see. I'd bet there is something a lot more useful you could spend your efforts on.
Lo-Fi Version | Time is now: 8th June 2024 - 05:09 PM |
