Valve lash, With WEBCAM #494 |
jeffdon |
Mar 13 2010, 06:09 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Ran the 2056 on the stand for a last time to get the oil warm, and do the initial change, and get her ready for installation. Did another valve check. Which got me to thinking.
I am setting it to the spec that came with the cam, .006 for both exhaust and intake. Lift (.465) and duration (280 deg.) are the same for both valves. Question is, if exhaust valves expand more due to heat than intake, why does webcam recommend .006 for both? Why not .006 and .008 as is standard? It SEEMS to be running pretty well, but I know i have a good deal of fooling around with jets and such once its on the road and i can test her under load. At one point at about 3500 rpm it started firing back through No 4., but that was right about the time i was running out of gas in my temp. tank. I shut it off, and got a big pop and some flame out the tail pipe. I would really like address/double check anything now, as its way easier accesing things on the stands. |
brant |
Mar 16 2010, 05:21 PM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Zach,
I apologize for not using the search feature I'm sure that Jake covers this very well on his site somewhere also. but do you have a link to the correct procedure I need to learn this tia brant |
VaccaRabite |
Mar 16 2010, 09:19 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Zach, I apologize for not using the search feature I'm sure that Jake covers this very well on his site somewhere also. but do you have a link to the correct procedure I need to learn this tia brant I have it saved somewhere at work. But if you search for it over on Jakes site you will find it. He wrote it. Zach |
jeffdon |
Mar 17 2010, 09:19 AM
Allrighty, will devise a nice mount for my dial indicator and check it more carefully. Just one more thing to keep me from actually putting the engine it. Which of course, means I can delay prepping and painting the engine bay. And thats a good thing, as i hate paint prep.
jeffdon |
Mar 20 2010, 01:45 PM
Allrighty, check it out. No 3 exhaust, half way though travel. My cam spec is .465 lift, both ex. and intake....i am getting .446, which is under 5% variation. By my eye, the adjuster/valve orientation looks good. What do ya'll think? This is Stock push rods, P/C are 96mm (not sure on the height).
Should I go with it? Do I have to check all the other valves since the lift spec is same for Exhaust and intake? OOPS.....forgot the pic...think the angle of my DI could be too great for accuracy? . |
Lo-Fi Version | Time is now: 6th June 2024 - 05:40 PM |
