> distributer cleaning, what kind of lube?
scrz914
post Mar 21 2010, 10:56 AM
I was checking my trigger points, trying to figure out why I'm only running on two cylinders and decided to take apart my distributer and clean it real good. All parts moved freely and were well lube, although it seemed like an over abundance of lube (and little bits of plant leaves). So know that I have it spotless, what are the only parts that should get lubricated? The advance plates, the little ball bearing thing, and the cams for the trigger points. Any other places? And would a moly-lube work well or is there something specific. My trigger points seemed fine. Also I was surprised to see my dist was a 205F and I have a '73 2.0. The 205f per Mr. Anders is from a '70 1.7. But they're pretty much all the same, right? (IMG:style_emoticons/default/confused24.gif)
Thanks for your help
Cap'n Krusty
post Mar 21 2010, 01:31 PM
Cap'n Krusty
Use Bosch or Delco point grease for the distributor cams. Motor oil for the felt pad in the shaft. The Cap'n
- Lo-Fi Version Time is now: 3rd July 2025 - 12:28 PM
