Tunnel Tubes, need to replace 'em, what else can I use? |
Gigamight |
Mar 21 2010, 09:26 PM
Member Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East |
Well, I have to replace the entire tunnel. While working on it, I cut into the tubes (IMG:style_emoticons/default/headbang.gif) so I cut the tunnel out of my parts car. I thought I had a good clutch tube in the parts car.... WRONG... So now I am trying to figure out how I am going to replace that, and while I'm at it, I am figuring on the likelihood that I will f' up the rest of the tubes.
So, has anyone replaced the tubes with something other than OEM? If so, what works good? I will be basically rebuilding the entire tunnel with it out of the car, so has anyone devised a particularly efficient way of anchoring the tubes while the tunnel is out? I want to rebuild this right the first time since I did it all the wrong ways so far. By the way, the car is a 72, the replacement tunnel is from a 74. I am using the complete shift setup from the 74 if that makes a difference. Thanks in advance. |
Tom_T |
Mar 21 2010, 09:40 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Well, I have to replace the entire tunnel. While working on it, I cut into the tubes (IMG:style_emoticons/default/headbang.gif) so I cut the tunnel out of my parts car. I thought I had a good clutch tube in the parts car.... WRONG... So now I am trying to figure out how I am going to replace that, and while I'm at it, I am figuring on the likelihood that I will f' up the rest of the tubes. So, has anyone replaced the tubes with something other than OEM? If so, what works good? I will be basically rebuilding the entire tunnel with it out of the car, so has anyone devised a particularly efficient way of anchoring the tubes while the tunnel is out? I want to rebuild this right the first time since I did it all the wrong ways so far. By the way, the car is a 72, the replacement tunnel is from a 74. I am using the complete shift setup from the 74 if that makes a difference. Thanks in advance. Do your tunnel fuel lines with the SS ones from Tangerine Racing - a member vendor on here. IIRC - the clutch tube may still be available new from Porsche, AA, PP, Pelican, etc. - otherwise either used or a cut-to-length of SS or mild steel tube & weld in place of stock. |
Lo-Fi Version | Time is now: 14th June 2024 - 04:51 AM |
