| smooth_eddy |
Mar 21 2010, 07:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
My Optima 34R battery only lasted for 5 1/2 years. I only drive about 1000 miles a year, which may be part of my problems? Anyway, last month I bought a Battery Tender Jr. which will charge the battery, but within one day, the battery looses it's charge. I check battery voltage with a Fluke meter and a it reads 12.34 volts at rest, and 13 volts at 1100 RPM. So I assume this is a good charging voltage?
I have been researching batteries online and have seen many poor reviews for the Optima batteries. Is there a better battery for 914's? Where is the best place to buy a new battery? Thanks..... |
| Tom_T |
Mar 23 2010, 06:45 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Battery life isn't so much dependent upon miles driven, as type of use & age ..... they all age, which is why the mfgrs. warranty them for a certain number of months. Some folks go with the deep cycle or marine batteries when their car sits long between uses, as yours sounds like you do, because they stand up better to the intermittent use..
If that Optima were warrantied for 60-66 mos., then you got what you paid for & you'll have to replace them every so often in time (not miles). If the warranty was for a longer time, take it back & get a prorated discount on a new one. I've used Interstates in my other cars for years with good luck, & the last one in the 914 before she went on stilts in 85 - all with good luck over the warranty period. They sell some in 75 mo. warranty - but just had one in my kids' Honda go after 15 (partly due to a failing Alt.) which they replaced at no cost (their warranty is free replacement in the first 18 mos, then prorated out to 75). I also had one from 2001 in our 88 Westy last up to last year (8+ years). It just varies. That said, I'll go with an Optima or other non-liquid-type battery in my 914 after my resto, so as to avoid the risk of battery acid damage in the hell hole. Optima's are a gel cell (i.e.: not a traditional water in the cells lead-acid), whereas the Interstates are standard water cell type. I don't know about the Odyssy discussed above, as it says dry cell - which may be better yet, if not too big for the battery tray & limited space in a 914. |
| smooth_eddy |
Mar 23 2010, 07:04 PM
Battery life isn't so much dependent upon miles driven, as type of use & age ..... they all age, which is why the mfgrs. warranty them for a certain number of months. Some folks go with the deep cycle or marine batteries when their car sits long between uses, as yours sounds like you do, because they stand up better to the intermittent use.. If that Optima were warrantied for 60-66 mos., then you got what you paid for & you'll have to replace them every so often in time (not miles). If the warranty was for a longer time, take it back & get a prorated discount on a new one. I've used Interstates in my other cars for years with good luck, & the last one in the 914 before she went on stilts in 85 - all with good luck over the warranty period. They sell some in 75 mo. warranty - but just had one in my kids' Honda go after 15 (partly due to a failing Alt.) which they replaced at no cost (their warranty is free replacement in the first 18 mos, then prorated out to 75). I also had one from 2001 in our 88 Westy last up to last year (8+ years). It just varies. That said, I'll go with an Optima or other non-liquid-type battery in my 914 after my resto, so as to avoid the risk of battery acid damage in the hell hole. Optima's are a gel cell (i.e.: not a traditional water in the cells lead-acid), whereas the Interstates are standard water cell type. I don't know about the Odyssy discussed above, as it says dry cell - which may be better yet, if not too big for the battery tray & limited space in a 914. I looked at the Odyssy in the link above. It does not have conventional terminals. I want to keep things as stock as possible. I checked the warranty on my Optima and it was "N/A". I guess that means I am SOL. If someone has a photo of the Odyssy please post. Do they have a convention battery post model? what about the hold down? Will is fit in a 914 battery tray w/o modifications? Thanks, Eddy |
smooth_eddy Battery Questions (problems) Mar 21 2010, 07:11 AM
smooth_eddy :bump: :bump:
My Optima 34R battery only lasted ... Mar 23 2010, 06:09 PM
rebelmdot http://www.odysseybatteries.com/battery/pc925.htm
... Mar 23 2010, 06:14 PM
bfrymire
http://www.odysseybatteries.com/battery/pc925.htm... Mar 23 2010, 06:27 PM
bfrymire
You can get the Odyssey battery with standard t... Mar 23 2010, 08:59 PM
Tom_T Eddy, per the Optima website, your 34R should have... Mar 23 2010, 09:02 PM
Dave_Darling I check battery voltage with a Fluke meter and a i... Mar 23 2010, 11:00 PM
pbanders
[quote name='smooth_eddy' post='1289683' date='Ma... Mar 24 2010, 12:43 PM
pbanders FWIW, I use a conventional Sears Diehard lead-acid... Mar 24 2010, 12:39 PM
smooth_eddy I will check Remi Battery and see if they will war... Mar 24 2010, 01:27 PM
Tom_T
I will check Remi Battery and see if they will wa... Mar 24 2010, 05:13 PM
Root_Werks Eddy, go to a Pacific Power Batteries locally. Lo... Mar 24 2010, 04:31 PM
underthetire I've heard a lot of bad about the Optima red t... Mar 24 2010, 05:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:04 PM |
