Ideas for repairing the carnage, Installed the front swaybar mounts |
bobhasissues |
Mar 23 2010, 03:10 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
If you have installed the inner triangle mounts for a front swaybar you had to hack up the ledge in the gas tank compartment so the triangles will fit in the right place. I had a real hard time getting my die grinder in there and ended up cutting more than I intended to. I have about a 1/4" gap on the ledge around the triangle plus an additional notch where the nut had to pass through. What did you do to patch up the carnage? Was thinking of welding in a small sheet metal patch, but was looking for some ideas.
davesprinkle |
Mar 23 2010, 08:03 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
What you describe is pretty typical. It doesn't affect the integrity of the car. Just cover it up with the fuel tank.
Lo-Fi Version | Time is now: 9th June 2024 - 03:52 PM |
