| smooth_eddy |
Mar 21 2010, 07:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
My Optima 34R battery only lasted for 5 1/2 years. I only drive about 1000 miles a year, which may be part of my problems? Anyway, last month I bought a Battery Tender Jr. which will charge the battery, but within one day, the battery looses it's charge. I check battery voltage with a Fluke meter and a it reads 12.34 volts at rest, and 13 volts at 1100 RPM. So I assume this is a good charging voltage?
I have been researching batteries online and have seen many poor reviews for the Optima batteries. Is there a better battery for 914's? Where is the best place to buy a new battery? Thanks..... |
| Tom_T |
Mar 23 2010, 09:02 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Eddy, per the Optima website, your 34R should have had a 72 mo. (6yr.) warranty, with the first 36 mos. free 100% repl. & next 36 prorated. See here:
http://www.optimabatteries.com/optima_prod...anty/preFeb.php Note that when you go there, that the new post Jan 09 warranty drops significantly by dropping the 2nd 36 mo. prorated period, per here: http://www.optimabatteries.com/optima_prod...nty/postFeb.php You should either have the original receipt from your/PO's purchase, or it's marked or punched on the battery label by law. It's possible that a PO had it for 6 mos. or so before you, negating any possible remaining warranty time. Otherwise, the only reason I can see that a warranty would show up as n/a, would be an NOS or black market sale?? BTW - I think they sell terminal adapters for non-standard batteries like that Odyssy. At the high cost of Optimas, that new POS halved warranty could make me change my mind in favor of Interstate sealed or another battery type! (IMG:style_emoticons/default/dry.gif) |
smooth_eddy Battery Questions (problems) Mar 21 2010, 07:11 AM
smooth_eddy :bump: :bump:
My Optima 34R battery only lasted ... Mar 23 2010, 06:09 PM
rebelmdot http://www.odysseybatteries.com/battery/pc925.htm
... Mar 23 2010, 06:14 PM
bfrymire
http://www.odysseybatteries.com/battery/pc925.htm... Mar 23 2010, 06:27 PM
Tom_T Battery life isn't so much dependent upon mile... Mar 23 2010, 06:45 PM
smooth_eddy
Battery life isn't so much dependent upon mil... Mar 23 2010, 07:04 PM
bfrymire
You can get the Odyssey battery with standard t... Mar 23 2010, 08:59 PM
Dave_Darling I check battery voltage with a Fluke meter and a i... Mar 23 2010, 11:00 PM
pbanders
[quote name='smooth_eddy' post='1289683' date='Ma... Mar 24 2010, 12:43 PM
pbanders FWIW, I use a conventional Sears Diehard lead-acid... Mar 24 2010, 12:39 PM
smooth_eddy I will check Remi Battery and see if they will war... Mar 24 2010, 01:27 PM
Tom_T
I will check Remi Battery and see if they will wa... Mar 24 2010, 05:13 PM
Root_Werks Eddy, go to a Pacific Power Batteries locally. Lo... Mar 24 2010, 04:31 PM
underthetire I've heard a lot of bad about the Optima red t... Mar 24 2010, 05:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:59 PM |
