Mounting dial indicator on head |
watsonrx13 |
Mar 26 2010, 03:58 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I'm in the process of checking the lift of the new cams I purchased from Jake. I would like to verify that I have the dial indicator positioned correctly to check the lift. Is this correct?
-- Rob |
McMark |
Mar 27 2010, 07:20 PM
Did you get the rocker arms from Jake? If so they should already be clearanced.
You'll need to back the adjuster screw nearly till it stops, and then check half lift alignment. |
watsonrx13 |
Mar 27 2010, 07:32 PM
Did you get the rocker arms from Jake? If so they should already be clearanced. You'll need to back the adjuster screw nearly till it stops, and then check half lift alignment. No, I did not get the rocker arms from Jake. If they need to be clearanced, how much material should be removed? Can a local machinist tackle this? -- Rob |
Lo-Fi Version | Time is now: 11th June 2024 - 04:15 AM |
