Correct "914" "2.0" Emblem Placement |
detoxcowboy |
Feb 4 2010, 09:10 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I just ditched my "euro" badge for the "914 2.0" and can't find the "famous thread" on where to place the emblem, w/ "Sahara" Steve's 914 precise example or something like that.. Thank You..
914werke |
Mar 30 2010, 01:48 AM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
what about the placement of the "stickers" on the 76 model? is that the same as the metal & plastic location w/o the holes?
Tom_T |
Mar 30 2010, 02:31 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
what about the placement of the "stickers" on the 76 model? is that the same as the metal & plastic location w/o the holes? Look at the pix in the Brian Long 914 & 914-6 book - latest edition, as it has pretty good rear end shots of a 75 or 76 & IIRC it's about the same as the earlier plastic & metal ones. If you can scan or photo that pic in the book (or similar), then print it enlarged to full 1:1 scale for that area showing the L edge of the R Taillight & the script, then you can use that as a template to transfer key points to place the decal script (you could use them for a pic of the metal/plastic formed script too assuming same placement). A non-staining grease pencil to mark the 4 corners of each script (through small holes punched in your template) will give you points along which you can place some thin blue low stick tape for the lines on 4 sides & space between 914 & 2.0, then place the decals as laid out! (IMG:style_emoticons/default/smile.gif) Also, make sure the surface is cleaned first for best adhesion & burnish the edges after you've squeezed out any bubbles. BTW - both 75 & 76 MY used the decals, 73 & 74 used the metal script at first but changed to plastic by later 73 or 74 MY. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:26 PM |
