Koni insert into Koni Strut |
my928s4 |
Mar 28 2010, 04:26 PM
Member Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest |
These are Koni inserts 8641-1077, the struts are Koni 911 341 079 10 and there seems to be a mismatch as the inserts hang up before fully inserted. I did not try gently tapping in with a rubber mallet I figured they were supposed to drop right in?
The picture shows where the insert start to hang up. Thoughts? |
Richard Casto |
Mar 30 2010, 03:26 PM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Glad I could help. It's always great when you can give someone info that actually helps them out! (IMG:style_emoticons/default/smile.gif)
It's also good you saw the bit about the special gland nut. By default the inserts are packaged with a gland nut for the Boge strut (as this is the most common strut). So if you are using a Koni strut, you have to buy the Koni Strut specific gland nuts as the thread pattern, etc. is different between the Boge and Koni struts. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:19 PM |
