> Bad poping noise when shifting, What is it?
914fun
post Mar 31 2010, 08:58 PM
Started hearing it last year. Sounds really bad now. Makes the same popping noise when I lightly accelerate. Is it the cv joints or something in the trans? Last year when I jacked up the car and put it in first and turned the tire there was lots of play at the trans not so much at the cv. So What is it that I need to replace? and is it costly? Thanks
VaccaRabite
post Mar 31 2010, 09:00 PM
En Garde!
I am assuming it is not exhaust popping on overrun? If so, it might just be an exhaust leak.
Zach
914fun
post Mar 31 2010, 09:17 PM
QUOTE(Vacca Rabite @ Mar 31 2010, 10:00 PM) *
Zach
NO, Its in the trans. or cv. Very mechanical sound. Very loud even when starting off very slow. and puting around. Its like something is not catching for a second. and then bam and I can feel it catch just touching the pedal lightly.
914fun   Bad poping noise when shifting   Mar 31 2010, 08:58 PM
Vacca Rabite   I am assuming it is not exhaust popping on overrun...   Mar 31 2010, 09:00 PM
914fun   I am assuming it is not exhaust popping on overru...   Mar 31 2010, 09:17 PM
RJMII   Did you try taking it out of gear while rotating e...   Mar 31 2010, 09:32 PM
Vacca Rabite   :agree: Check your CVs. Its an easy thing to che...   Mar 31 2010, 09:38 PM
914fun   when I spin the wheel and stop it, going both dir...   Mar 31 2010, 09:54 PM
RJMII   Tail shift or side shift? Unless you're a CC...   Mar 31 2010, 10:12 PM
914fun   Tail shift or side shift? Unless you're a C...   Mar 31 2010, 10:22 PM
RJMII   shipping (x2) $100 (probably less) rebuild ...   Mar 31 2010, 10:34 PM
Elliot Cannon   I have the same bad popping noise when I shift but...   Mar 31 2010, 10:48 PM
Vacca Rabite   Hold on a tick. If there is "lots of play...   Apr 1 2010, 08:50 AM
tat2dphreak   :agree: I had a wheel bearing heading south on ...   Apr 1 2010, 08:55 AM
914fun   I went out this morning and raised the back tires ...   Apr 1 2010, 10:09 AM
tat2dphreak   understood... I've had mine for 6 years and i...   Apr 1 2010, 10:16 AM
Vacca Rabite   Oh, I guess I misinterpreted your prior post. Sou...   Apr 1 2010, 10:32 AM
RJMII   http://www.914world.com/bbs2/index.php?showtopic=5...   Apr 1 2010, 11:56 AM
kwales   I'm almost thinking the pinion shaft is moving...   Apr 1 2010, 12:10 PM
914fun   Wow! finely got it running again, Crap! st...   Apr 2 2010, 03:05 PM
Dr Evil   Yikes, it sounds like possibly multiple things. Al...   Apr 3 2010, 12:37 AM
- Lo-Fi Version Time is now: 8th July 2025 - 08:48 PM
