I need ideas! |
I need ideas! |
mskinner |
Apr 1 2010, 11:08 AM
Newbie Group: Members Posts: 7 Joined: 11-March 10 From: Kansas City Member No.: 11,455 Region Association: None |
So my 914 is in great shape except for the windshield frame is bent. This fact and the fact that buying a new windshield in the Kansas area is seemingly impossible. I am looking for ideas on removing the windshield frame and replacing it with some sort of faring or whatever you suggest. What has been done before? And what looks good? Any ideas would be a huge help. Thanks.
davep |
Apr 1 2010, 11:48 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I agree that the frame should be repaired without cutting if possible.
The one trick to installing the glass is to make sure it sits deep enough, and centered, that the trim will go on correctly. The glass sits below the level of the frame. I have seen one car that the owner cut the frame off flush with the cowl, then engineered a pin system the same as the 356 Speedster to be able to install the glass when required, or otherwise run with a Ginther windscreen. This was on a race car, that was never street driven: 9140430033 |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:24 PM |
