> Painting question, color coat is too soft to sand
Gudhjem
post Apr 4 2010, 12:21 AM
I've begun painting my car, panel-by-panel, starting with the trunk lid.
I'm using Interlux Bridghtsides paint. Yes, I'm rolling it on, mostly because I don't have a large compressor and because I am hoping to avoid all the mess of spraying in my garage.
I spent a few days patching holes (luggage rack once upon a time I think), and spent a few days putting on a few coats of primer. Sanding the primer was no problem, and I've now started with the color. Problem is, when I try to sand the paint, it sticks to the paper. There's no dust created, the paper just gets clogged right away. It's as if the paint's not dry. The can says leave it at least 16 hours, I've left it 28, and it's not cold in California.
Anyone know what's going on? (IMG:style_emoticons/default/confused24.gif)
--Steve
Here's before primer
After Primer
Sanding Block after trying to color sand
wrightee
post Apr 4 2010, 06:19 AM
I used this paint quite a few years ago, but on a boat (fiberglass). I'm thinking either the paint needs longer to cure on steel, or you may be sanding too hard?
For boat application, I used a foam roller and an almost dry, high quality badger hair brush to smooth out behind the roller. Ended up with a pretty good "10 foot job" (which is about as close as most people get to look at a boat) - I'd want something better on a car, though.
Gudhjem   Painting question   Apr 4 2010, 12:21 AM
ConeDodger   Are you supposed to use a hardener? I don't th...   Apr 4 2010, 12:25 AM
Gudhjem   Are you supposed to use a hardener? I don't t...   Apr 4 2010, 12:48 AM
messix   are you wet sanding?   Apr 4 2010, 12:54 AM
Racer Chris   From what I read after a google search, it should ...   Apr 4 2010, 01:21 AM
wrightee   I used this paint quite a few years ago, but on a ...   Apr 4 2010, 06:19 AM
rick 918-S   Boat paint is formulated with an elastic property ...   Apr 4 2010, 07:31 AM
jd74914   BTW: You will notice the finish will chalk and re...   Apr 4 2010, 08:23 AM
scotty b   :hang: It's a car not a boat :alfred: When you...   Apr 4 2010, 08:40 AM
Lennies914   I have seen marine paint professionally applied, o...   Apr 4 2010, 08:49 AM
9146986   I'll 2nd Scotty on this. You are trying to sa...   Apr 4 2010, 10:35 AM
realred914   cure time of teh primer is very important before y...   Apr 4 2010, 11:10 AM
burton73   You would have been better off with a Wagner power...   Apr 4 2010, 12:54 PM
Gudhjem   Thanks for all the replies. Why would I use a sin...   Apr 4 2010, 04:13 PM
rick 918-S   Thanks for all the replies. I was not aware that...   Apr 4 2010, 05:57 PM
quikshft   Well my hat is off to you for giving something dif...   Apr 5 2010, 03:14 PM
7TPorsh   Check my build thread. I rolled....big mistake. en...   Apr 5 2010, 03:54 PM
Rob-O 1167   That thread link doesn't seem to work...   Apr 6 2010, 06:53 AM
7TPorsh   Here is a shot of the car after the first roll. Ca...   Apr 6 2010, 04:31 PM
underthetire   Believe it or not, a guy here thinned rustoleum pa...   Apr 6 2010, 05:14 PM
7TPorsh   Maybe it's an enamel vs. polyurethane thing.   Apr 6 2010, 05:19 PM
r_towle   I want to do a roller job, just to see if I can ma...   Apr 6 2010, 06:48 PM
- Lo-Fi Version Time is now: 9th July 2025 - 04:04 PM
