Gudhjem |
Member ![]() ![]() Group: Members Posts: 133 Joined: 29-March 07 From: Castro Valley, CA Member No.: 7,629 Region Association: Northern California ![]() |
I've begun painting my car, panel-by-panel, starting with the trunk lid.
I'm using Interlux Bridghtsides paint. Yes, I'm rolling it on, mostly because I don't have a large compressor and because I am hoping to avoid all the mess of spraying in my garage. I spent a few days patching holes (luggage rack once upon a time I think), and spent a few days putting on a few coats of primer. Sanding the primer was no problem, and I've now started with the color. Problem is, when I try to sand the paint, it sticks to the paper. There's no dust created, the paper just gets clogged right away. It's as if the paint's not dry. The can says leave it at least 16 hours, I've left it 28, and it's not cold in California. Anyone know what's going on? (IMG:style_emoticons/default/confused24.gif) --Steve Here's before primer ![]() After Primer ![]() Sanding Block after trying to color sand ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,829 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I'll 2nd Scotty on this. You are trying to sand and buff a paint that isn't really meant for that kind of finish. The paint lays down well when brushed or rolled because that's all you should do to it. It's always going to be rubbery, and gum up whatever abrasive you try and use.
Lo-Fi Version | Time is now: 9th July 2025 - 04:29 PM |
