| casey944 |
Apr 5 2010, 07:12 AM
Member ![]() ![]() Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region |
There was some info on the "other site", that i have completely given up on, regarding a throttle cable for 914s.
What do you recommend? OEM? Is there a better aftermarket solution? Thanks in advance. |
| r_towle |
Apr 5 2010, 10:14 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
First off...Call George and have him put two cables on your order...
Put the spare one in the trunk...you will thank me someday within the next 5 years. Remove drivers side carpet. Remove plywood pedal board..it does come out, a few allen head bolts and it really does come out without breaking it....its just a bit of an odd puzzle... If you have a center console...remove it and put it on the passenger floor. Remove the cable end that attaches to the gas pedal on the pedal cluster. Pull out the broken end via the front. Disconnect the cable at the throttle body and feed it under the car. Pull it out of the tube. Slide new one in (greased and lubed) Hook it all back up. |
casey944 Need suggestions for a throttle cable Apr 5 2010, 07:12 AM
casey944 http://www.zimsautotechnik.net/acatalog/Te...__914... Apr 5 2010, 07:55 AM
pcar916 :agree:
Terry is the best, by far. Apr 5 2010, 07:57 AM
dr914@autoatlanta.com stock works great just make sure that it is the or... Apr 5 2010, 08:53 AM
tat2dphreak get a Terry cable. they work great! Apr 5 2010, 09:16 AM
casey944 Taking George's recommendation and I ordered a... Apr 5 2010, 09:20 AM
Nie Zu Alt George,
What's the story on the Italian one ... Apr 5 2010, 09:36 AM
casey944 Anybody have an idea of how long it takes to insta... Apr 5 2010, 09:51 AM
tat2dphreak
about 10 minutes if the car is already up where y... Apr 5 2010, 10:04 AM
jt914-6
First off...Call George and have him put two cabl... Apr 5 2010, 10:20 AM
Tom_T
[quote name='r_towle' post='1297858' date='Apr 5 ... Apr 5 2010, 02:42 PM
jeffdon
[quote name='r_towle' post='1297858' date='Apr 5... Apr 5 2010, 04:06 PM
tat2dphreak
:agree: totally! clutch cable too!
FWIW,... Apr 5 2010, 10:25 AM
r_towle
FWIW... Apr 5 2010, 10:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:43 PM |
