> running on #1 and #3 only (2.0 four)
dflesburg
post Apr 5 2010, 12:02 PM
spraying fuel out tail pipe.
new cap, rotor, plugs, wires, points, condensor
disabled cold start line.
checked MPS for vacume.
thinking it might be trigger points.
experienced thoughts please....
TheCabinetmaker
post Apr 5 2010, 12:10 PM
I drive my car everyday
Trigger points fire in pairs. 1&3 and 2&4. Turn the connector on the diz around, I'll bet the other two fire.
Edit: wait! you said fuel out the tail pipe. Trigger points wouldn't cause that (I don't think). No pulse, no fuel. Sounds like your getting fuel, but no spark.
dflesburg   running on #1 and #3 only (2.0 four)   Apr 5 2010, 12:02 PM
vsg914   Trigger points fire in pairs. 1&3 and 2&4....   Apr 5 2010, 12:10 PM
rmital   thinking it might be trigger points. :agree:   Apr 5 2010, 12:11 PM
r_towle   Also check your grounds on the top case bolt, rear...   Apr 5 2010, 12:15 PM
realred914   running on #1 and #3 only (2.0 four) spraying f...   Apr 5 2010, 12:15 PM
rmital   actually it is more likely the grounds: diagonal f...   Apr 5 2010, 12:21 PM
rmital   actually it is more likely the grounds: diagonal ...   Apr 5 2010, 12:22 PM
realred914   actually it is more likely the grounds: diagonal ...   Apr 5 2010, 12:52 PM
dr914@autoatlanta.com   Fuel coming out of the tail pipe I would GUESS the...   Apr 5 2010, 12:23 PM
dflesburg   wouldnt disconnecting the fuel line to the cold st...   Apr 5 2010, 12:40 PM
Cap'n Krusty   The cold start valve has NOTHING to do with the CH...   Apr 5 2010, 01:52 PM
Root_Werks   Years ago I had a 74' 2.0 FI that was running ...   Apr 5 2010, 02:56 PM
dflesburg   So if my valves are not closing all the way on 1 a...   Apr 7 2010, 07:59 AM
Root_Werks   One of a few things that could be causing the issu...   Apr 7 2010, 08:27 AM
dflesburg   okay, before everyone starts making fun of me... ...   Apr 7 2010, 08:37 AM
Root_Werks   okay, before everyone starts making fun of me... ...   Apr 7 2010, 08:46 AM
fly   Injectors dont all work I had a similar problem w...   Apr 10 2010, 12:57 PM
dflesburg   Issue Resolved... #2 Fuel injector leaking like a...   Apr 13 2010, 06:37 AM
- Lo-Fi Version Time is now: 15th April 2026 - 03:06 PM
