> running on #1 and #3 only (2.0 four)
dflesburg
post Apr 5 2010, 12:02 PM
spraying fuel out tail pipe.
new cap, rotor, plugs, wires, points, condensor
disabled cold start line.
checked MPS for vacume.
thinking it might be trigger points.
experienced thoughts please....
Root_Werks
post Apr 5 2010, 02:56 PM
Village Idiot
Years ago I had a 74' 2.0 FI that was running crazy rich, I tried what seemed like everything. I took it to a local shop giving up and figured just spend the money. Really glad I did.
Wound up the ECU was double firing 2 of the injectors. The shop bench tested the trigger points to be good, but the injectors themselves were blinking the little diod tester thingy way to fast on 1&3 or 2&4, can't remember the pair anymore.
I was actually there when he discovered this. One of his Mechanics ran home and drove his 75' 2.0 914 into work. We swapped ECU's for a dummy's test, ran perfect.
Back then, I just had my ECU rebuilt for I think $75.
Might be something similar? (IMG:style_emoticons/default/confused24.gif)
dflesburg   running on #1 and #3 only (2.0 four)   Apr 5 2010, 12:02 PM
vsg914   Trigger points fire in pairs. 1&3 and 2&4....   Apr 5 2010, 12:10 PM
rmital   thinking it might be trigger points. :agree:   Apr 5 2010, 12:11 PM
r_towle   Also check your grounds on the top case bolt, rear...   Apr 5 2010, 12:15 PM
realred914   running on #1 and #3 only (2.0 four) spraying f...   Apr 5 2010, 12:15 PM
rmital   actually it is more likely the grounds: diagonal f...   Apr 5 2010, 12:21 PM
rmital   actually it is more likely the grounds: diagonal ...   Apr 5 2010, 12:22 PM
realred914   actually it is more likely the grounds: diagonal ...   Apr 5 2010, 12:52 PM
dr914@autoatlanta.com   Fuel coming out of the tail pipe I would GUESS the...   Apr 5 2010, 12:23 PM
dflesburg   wouldnt disconnecting the fuel line to the cold st...   Apr 5 2010, 12:40 PM
Cap'n Krusty   The cold start valve has NOTHING to do with the CH...   Apr 5 2010, 01:52 PM
Root_Werks   Years ago I had a 74' 2.0 FI that was running ...   Apr 5 2010, 02:56 PM
dflesburg   So if my valves are not closing all the way on 1 a...   Apr 7 2010, 07:59 AM
Root_Werks   One of a few things that could be causing the issu...   Apr 7 2010, 08:27 AM
dflesburg   okay, before everyone starts making fun of me... ...   Apr 7 2010, 08:37 AM
Root_Werks   okay, before everyone starts making fun of me... ...   Apr 7 2010, 08:46 AM
fly   Injectors dont all work I had a similar problem w...   Apr 10 2010, 12:57 PM
dflesburg   Issue Resolved... #2 Fuel injector leaking like a...   Apr 13 2010, 06:37 AM
- Lo-Fi Version Time is now: 15th April 2026 - 03:01 PM
