Day 2 with car. HELP!, Water in the motor. |
Silverstreak |
Apr 5 2010, 11:53 PM
Edmund J. Fournier #36 Group: Members Posts: 117 Joined: 2-April 10 From: Pensacola Member No.: 11,552 Region Association: South East States |
Well I bought my 914 Sunday. Started work on it today. Let me first tell you that the rear deck lid was pushed back so the engine cover wasn't closed all the way. Also the throttle was stuck and one of the carbs was wide open. So, subsequently rain poored in through said wide open carb because one of the wing nuts that held the aircleaner on was missing. Drained the oil today and the first quart was pure water the rest a nasty grey mix and at the end mostly oil. There was no signs of rust in the water or oil as I believe this occured recently because the accident that bent and pushed the rear decklid happened recently and the car didn't sit too long. Anyway, I'm open to suggestions, I suspect I should probably tear the engine down and rebuild. But if there is any other option (besides dropping in a different motor) I'd love to hear it? Thanks in advance.
Cheers, Josh |
VaccaRabite |
Apr 6 2010, 10:29 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Can you turn the engine over by hand? If it is not seized, i'd not be too worried, until you had good reason to be worried. (IMG:style_emoticons/default/smile.gif)
And I'd suggest filling the cylinders that let the water in with diesel, K1, or some sort of penetrating oil, as the rings are probably rusted to the cylinders. Zach |
Lo-Fi Version | Time is now: 11th June 2024 - 02:26 AM |
