> running on #1 and #3 only (2.0 four)
dflesburg
post Apr 5 2010, 12:02 PM
spraying fuel out tail pipe.
new cap, rotor, plugs, wires, points, condensor
disabled cold start line.
checked MPS for vacume.
thinking it might be trigger points.
experienced thoughts please....
Root_Werks
post Apr 7 2010, 08:27 AM
Village Idiot
One of a few things that could be causing the issue.
You have to start with a few of the basic known goods BEFORE suspecting the FI:
Good valve adjustment, not that one was just completed, but done correctly or plug wires weren't crossed.
Other simple things like, points, cap, plugs and wires all in good or new condition.
I assume all that has already been verified good and correct which leads to some sort of FI issue. Like others have already said, could be trigger points, my thought was a bad ECU and so on.
Do you have anyone local you can swap out a part or two with?
Swap out the MPS, no change, put old one back.
Swap out ECU, no change, put old one back and so on.
Keep us posted! (IMG:style_emoticons/default/bye1.gif)
dflesburg   running on #1 and #3 only (2.0 four)   Apr 5 2010, 12:02 PM
vsg914   Trigger points fire in pairs. 1&3 and 2&4....   Apr 5 2010, 12:10 PM
rmital   thinking it might be trigger points. :agree:   Apr 5 2010, 12:11 PM
r_towle   Also check your grounds on the top case bolt, rear...   Apr 5 2010, 12:15 PM
realred914   running on #1 and #3 only (2.0 four) spraying f...   Apr 5 2010, 12:15 PM
rmital   actually it is more likely the grounds: diagonal f...   Apr 5 2010, 12:21 PM
rmital   actually it is more likely the grounds: diagonal ...   Apr 5 2010, 12:22 PM
realred914   actually it is more likely the grounds: diagonal ...   Apr 5 2010, 12:52 PM
dr914@autoatlanta.com   Fuel coming out of the tail pipe I would GUESS the...   Apr 5 2010, 12:23 PM
dflesburg   wouldnt disconnecting the fuel line to the cold st...   Apr 5 2010, 12:40 PM
Cap'n Krusty   The cold start valve has NOTHING to do with the CH...   Apr 5 2010, 01:52 PM
Root_Werks   Years ago I had a 74' 2.0 FI that was running ...   Apr 5 2010, 02:56 PM
dflesburg   So if my valves are not closing all the way on 1 a...   Apr 7 2010, 07:59 AM
Root_Werks   One of a few things that could be causing the issu...   Apr 7 2010, 08:27 AM
dflesburg   okay, before everyone starts making fun of me... ...   Apr 7 2010, 08:37 AM
Root_Werks   okay, before everyone starts making fun of me... ...   Apr 7 2010, 08:46 AM
fly   Injectors dont all work I had a similar problem w...   Apr 10 2010, 12:57 PM
dflesburg   Issue Resolved... #2 Fuel injector leaking like a...   Apr 13 2010, 06:37 AM
- Lo-Fi Version Time is now: 15th April 2026 - 03:09 PM
