| dflesburg |
Apr 5 2010, 12:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
running on #1 and #3 only (2.0 four)
spraying fuel out tail pipe. new cap, rotor, plugs, wires, points, condensor disabled cold start line. checked MPS for vacume. thinking it might be trigger points. experienced thoughts please.... |
| dflesburg |
Apr 7 2010, 08:37 AM
okay, before everyone starts making fun of me...
QUOTE You have to start with a few of the basic known goods BEFORE suspecting the FI: Good valve adjustment, not that one was just completed, but done correctly Lets say we never did adjust the valves. Bought the engine a couple years ago and just put it in and drove it. Drove it around about a year now. never adjusted the valves... |
| Root_Werks |
Apr 7 2010, 08:46 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,946 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
okay, before everyone starts making fun of me... QUOTE You have to start with a few of the basic known goods BEFORE suspecting the FI: Good valve adjustment, not that one was just completed, but done correctly Lets say we never did adjust the valves. Bought the engine a couple years ago and just put it in and drove it. Drove it around about a year now. never adjusted the valves... Probably not the issue then. Not trying to poke at anyone's mechanical skills, but has anything been touched or changed.....like spark plug wires? Trying to get a baseline for variables. If nothing was changed, then the issue is most likely a failed FI part. (IMG:style_emoticons/default/wink.gif) |
dflesburg running on #1 and #3 only (2.0 four) Apr 5 2010, 12:02 PM
vsg914 Trigger points fire in pairs. 1&3 and 2&4.... Apr 5 2010, 12:10 PM
rmital
:agree: Apr 5 2010, 12:11 PM
r_towle Also check your grounds on the top case bolt, rear... Apr 5 2010, 12:15 PM
realred914
spraying f... Apr 5 2010, 12:15 PM
rmital actually it is more likely the grounds:
diagonal f... Apr 5 2010, 12:21 PM
rmital
diagonal ... Apr 5 2010, 12:22 PM
realred914
diagonal ... Apr 5 2010, 12:52 PM
dr914@autoatlanta.com Fuel coming out of the tail pipe I would GUESS the... Apr 5 2010, 12:23 PM
dflesburg wouldnt disconnecting the fuel line to the cold st... Apr 5 2010, 12:40 PM
Cap'n Krusty The cold start valve has NOTHING to do with the CH... Apr 5 2010, 01:52 PM
Root_Werks Years ago I had a 74' 2.0 FI that was running ... Apr 5 2010, 02:56 PM
dflesburg So if my valves are not closing all the way on 1 a... Apr 7 2010, 07:59 AM
Root_Werks One of a few things that could be causing the issu... Apr 7 2010, 08:27 AM
fly Injectors dont all work
I had a similar problem w... Apr 10 2010, 12:57 PM
dflesburg Issue Resolved...
#2 Fuel injector leaking like a... Apr 13 2010, 06:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 04:51 PM |
