> Can we play... Name That Part?, cleaning out the trunks, finding odds n ends
Gigamight
post Apr 7 2010, 02:58 PM
Region Association: Middle East
let me know if you know this stuff. Some of it may be obvious, but remember that I am still learning. Other parts, I am just wondering if they belong to a 72. All of this that is worth anything will likely end up in the classifieds as soon as it is identified, so if you want it, let me know.
Pic 1)
Gigamight
post Apr 7 2010, 03:03 PM
pic 5)
70_914
post Apr 7 2010, 06:32 PM
QUOTE(Gigamight @ Apr 7 2010, 02:03 PM) *
pic 5)
Bus engine bar. Matches the bus engine bar that came with my 2.0 crank and rods (still in worthless bus block, attached to worthless bus pistons, hitting worthless bus valves, mounted in worthless bus heads).
Bar should be worth quite a bit of money! (IMG:style_emoticons/default/lol-2.gif)
Gigamight   Can we play... Name That Part?   Apr 7 2010, 02:58 PM
tat2dphreak   I know! radio ;)   Apr 7 2010, 02:59 PM
Gigamight   I know! radio ;) smartass ;) hold on, lots...   Apr 7 2010, 03:00 PM
Gigamight   pic 2)   Apr 7 2010, 02:59 PM
dr914@autoatlanta.com   pic 2) beetle pressure plate   Apr 7 2010, 03:04 PM
realred914   pic 2) beetle pressure plate I dont think so...   Apr 7 2010, 10:47 PM
Gigamight   pic 3)   Apr 7 2010, 03:01 PM
dr914@autoatlanta.com   pic 3) 356 beetle starter 914 early 911 s...   Apr 7 2010, 03:07 PM
tat2dphreak   one on the right is a 914 starter, but the one o...   Apr 7 2010, 03:02 PM
Gigamight   pic 4)   Apr 7 2010, 03:02 PM
70_914   pic 4) If this is for a 914 it might be worth m...   Apr 7 2010, 06:39 PM
Gigamight   pic 5)   Apr 7 2010, 03:03 PM
dr914@autoatlanta.com   pic 5) 70-72 914 engine mounting bar   Apr 7 2010, 03:07 PM
Pat Garvey   pic 5) 70-72 914 engine mounting bar Nope -...   Apr 7 2010, 04:55 PM
Cap'n Krusty   [quote name='dr914@autoatlanta.com' post='1299462...   Apr 7 2010, 07:18 PM
70_914   pic 5) Bus engine bar. Matches the bus engine...   Apr 7 2010, 06:32 PM
Gigamight   pic 6)   Apr 7 2010, 03:04 PM
dr914@autoatlanta.com   pic 6) jetta golf rabbit starter?   Apr 7 2010, 03:05 PM
Gigamight   pic 7)   Apr 7 2010, 03:05 PM
dr914@autoatlanta.com   pic 7) coil solenoid 911 fuel pump   Apr 7 2010, 03:06 PM
tat2dphreak   early engine bar, pre- sideshift. is 4 an a/c co...   Apr 7 2010, 03:05 PM
Dr Evil   #2 is a pressure plate for a bus, likely. #3 is a ...   Apr 7 2010, 03:06 PM
Gigamight   pic 8)   Apr 7 2010, 03:06 PM
Gigamight   pic 9)   Apr 7 2010, 03:07 PM
dr914@autoatlanta.com   pic 9) vw brake drums   Apr 7 2010, 04:45 PM
Gigamight   pic 10)   Apr 7 2010, 03:08 PM
ClayPerrine   #6 is an internally regulated Bosch alternator. No...   Apr 7 2010, 03:09 PM
jt914-6   #4....trotline weight.....AKA smog pump.... :headb...   Apr 7 2010, 03:09 PM
Gigamight   pic 11) code on this is GC 07017   Apr 7 2010, 03:09 PM
Cap'n Krusty   Typical aftermarket radio with a plate from a T1 V...   Apr 7 2010, 03:11 PM
SLITS   Pic 3 .... one on left is an SR15X, Type 1 Bug sta...   Apr 7 2010, 03:13 PM
Gigamight   Pic 3 .... one on left is an SR15X, Type 1 Bug st...   Apr 7 2010, 03:18 PM
ClayPerrine   . (except for some trinkets I'm not showing ...   Apr 7 2010, 03:20 PM
SLITS   . (except for some trinkets I'm not showing...   Apr 7 2010, 03:22 PM
ClayPerrine   [quote name='ClayPerrine' post='1299486' date='Ap...   Apr 7 2010, 03:25 PM
SLITS   [quote name='ClayPerrine' post='1299486' date='A...   Apr 7 2010, 03:28 PM
Gigamight   [quote name='ClayPerrine' post='1299493' date='Ap...   Apr 7 2010, 03:41 PM
SLITS   [quote name='ClayPerrine' post='1299493' date='A...   Apr 7 2010, 04:12 PM
Gigamight   pic 12) one friggin picture won't load sigh.....   Apr 7 2010, 03:15 PM
ClayPerrine   #11 is a VW Rabbit gearbox. Also known as a boat...   Apr 7 2010, 03:16 PM
SLITS   forgot pic 7 Middle piece is the vibrating motor ...   Apr 7 2010, 03:18 PM
Root_Werks   All that fit in your trunks?!?! :blink:   Apr 7 2010, 03:18 PM
Gigamight   All that fit in your trunks?!?! :blink: ...   Apr 7 2010, 03:23 PM
Gigamight   wanna see the best thing I found after cleaning ou...   Apr 7 2010, 03:30 PM
underthetire   Porsche used a ND Denso smog pump???? Oh, looked...   Apr 7 2010, 04:35 PM
Slider   Pic 9 are actually Rabbit Drum brakes not type 1 ...   Apr 8 2010, 12:03 PM
rdauenhauer   Ever seen one of these?   May 11 2010, 11:20 AM
SLITS   Might be the hot air feed into the oil bath air cl...   May 11 2010, 11:25 AM
McMark   Yup, early 1.7 hot air feed tin.   May 11 2010, 11:36 AM
ConeDodger   Whatever you do, don't throw away that smog pu...   May 11 2010, 12:58 PM
SLITS   Whatever you do, don't throw away that smog p...   May 11 2010, 01:38 PM
rdauenhauer   Yup, early 1.7 hot air feed tin. :idea: never...   May 11 2010, 03:10 PM
- Lo-Fi Version Time is now: 14th July 2025 - 04:12 AM
