Day 2 with car. HELP!, Water in the motor. |
Silverstreak |
Apr 5 2010, 11:53 PM
Edmund J. Fournier #36 Group: Members Posts: 117 Joined: 2-April 10 From: Pensacola Member No.: 11,552 Region Association: South East States |
Well I bought my 914 Sunday. Started work on it today. Let me first tell you that the rear deck lid was pushed back so the engine cover wasn't closed all the way. Also the throttle was stuck and one of the carbs was wide open. So, subsequently rain poored in through said wide open carb because one of the wing nuts that held the aircleaner on was missing. Drained the oil today and the first quart was pure water the rest a nasty grey mix and at the end mostly oil. There was no signs of rust in the water or oil as I believe this occured recently because the accident that bent and pushed the rear decklid happened recently and the car didn't sit too long. Anyway, I'm open to suggestions, I suspect I should probably tear the engine down and rebuild. But if there is any other option (besides dropping in a different motor) I'd love to hear it? Thanks in advance.
Cheers, Josh |
realred914 |
Apr 7 2010, 11:19 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
I'd do a couple oil changes right way with a short operating time inbetween (several miutes of idleing) you dont want a lot of engine loads with oil / water mix, as water is not lubriaction to the engine. then drive it till fully warmed up for a while, that will boil off the water that remains. do this right away, worst thing is to put of the reapir as stuff will rust bad if you let it go |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:31 AM |
