will 80 PSI VDO gauge work with 150psi sender, hard to read this 150 psi gauge =/ |
qa1142 |
Apr 10 2010, 01:52 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
so got a 150 PSI gauge (picture at Jegs showed 80 psi dial) (IMG:style_emoticons/default/chair.gif)
hard to read Will 150 PSI dual sender work right with VDO 310012 80 PSI gauge? |
McMark |
Apr 10 2010, 07:52 PM
I'm not clear on what you have, exactly. (IMG:style_emoticons/default/blink.gif)
Your gauge is ______ psi. Your sender is _____ psi. I was just researching this for SirAndy. Both senders have a range of 0-180 ohm. If you have a 5 bar sender and a 10 bar gauge, the gauge will read fine, but you'll have to mentally 1/2 the numbers you see on the gauge. If you have a 10 bar sender and a 5 bar guage, again, the gauge will read fine, but you'll have to mentally double the numbers you see on the gauge. If you have a dual contact (pressure and warning light) 10 bar sender that you don't want, PM SirAndy because he's going to be buying on and you might be able to work something out. |
Lo-Fi Version | Time is now: 13th June 2024 - 05:30 AM |
